Page 1 of 2
Does anyone else follow this?
Posted: Sun Oct 28, 2012 8:46 pm
by Tile Diver
Just wondering if anyone else follows this?
Re: Does anyone else follow this?
Posted: Sun Oct 28, 2012 8:58 pm
by Noyjatat
Nope I just hope she stops when I push the middle pedal until the little yellow light comes on and she says "I need some new shoes!" then I take her shopping
And that's just the missus!
Posted: Tue Oct 30, 2012 1:46 am
by stu
Well the dealers don't. But they'll wave the piece of paper in your face and tell you that they're not honouring the Audi parts warranty if it hasn't been done
In my experience at least.
So, do it or be prepared to say you did it if anything goes wrong. For the record, I've done it three times. And now I have ceramics
Posted: Tue Oct 30, 2012 6:38 am
by Brooner
Very similar to this method i use and never had any problems with warped disks
http://zeckhausen.com/bedding_in_brakes.htm
Posted: Tue Oct 30, 2012 8:39 am
by Reffio
So this bedding in procedure should be done pretty much as soon as you get the car back from the stealers after installing new pads or discs (or both)?
Posted: Tue Oct 30, 2012 12:16 pm
by Tile Diver
Reffio wrote:So this bedding in procedure should be done pretty much as soon as you get the car back from the stealers after installing new pads or discs (or both)?
Well, I followed it anyway just to be safe and hopefully I'll have some kind of comeback if there is a disc warping problem before the parts warranty of 2 years is up!!!
It was a ballache and took around an hour and a half, trying to find a quiet road for that duration is near impossible.
Reffio, I think thats the general idea but there is no chance of the dealer doing this for you, and I suspect they may not even mention it to the customer after they fit new discs and pads, I could be wrong though!!
Posted: Tue Oct 30, 2012 1:48 pm
by adsgreen
2 year parts warranty won't apply to "warped" discs. They have an additional very low mileage warranty often not much more than 3k miles (on other marques).
bedding in is always good to do and worth repeating regulary to keep things in tip top condition. Normal day to day driving can be harder on the brakes than driving them hard and can prevent "warping" from pad deposits. Also generally stops the more track focussed setups from squealing.
Posted: Tue Oct 30, 2012 10:06 pm
by Tile Diver
adsgreen wrote:2 year parts warranty won't apply to "warped" discs. They have an additional very low mileage warranty often not much more than 3k miles (on other marques).
Thanks for the info man!!
Posted: Wed Oct 31, 2012 9:38 am
by Dom81
Same one as I've used - again, no problems
Posted: Wed Oct 31, 2012 10:41 am
by Tile Diver
All done, thanks to everyone's contributions!!
Posted: Thu Nov 01, 2012 3:45 pm
by Reffio
Oh well I guess it's another good excuse for tearing around in the car for a while! Although I as mentioned I'm not sure where you find a quiet bit of road to do the continued runs like that!
Posted: Thu Nov 01, 2012 6:27 pm
by Tile Diver
Reffio wrote:Oh well I guess it's another good excuse for tearing around in the car for a while! Although I as mentioned I'm not sure where you find a quiet bit of road to do the continued runs like that!
Exactly, and your right It wasn't easy on the road, I had the hazards on most of the time in fear of someound coming into the back of me!!!
Posted: Thu Nov 01, 2012 8:02 pm
by KernowPete
Did mine on a local disused arifield. Only problem was the concrete runways are breaking up pretty bad and there were massive potholes absolutely everywhere
Posted: Thu Nov 01, 2012 9:52 pm
by Tile Diver
KernowPete wrote:Did mine on a local disused arifield. Only problem was the concrete runways are breaking up pretty bad and there were massive potholes absolutely everywhere
Ideal, just not good for the DRS, hopefully no damage caused.
Posted: Fri Nov 02, 2012 12:20 am
by stu
Yup, the only way to do it safely and without affecting other road users is by doing it at night. I work on an 'on call' basis overnight quite a lot so I did it at around midnight on a completely empty rural road: the road from Newcastle to Jedborough (basically I went to Scotland and back
). Brilliant road for the way back when I could drive unrestricted, just had to watch out for the sheep.
