Page 1 of 2
Tyre Pressure warning errors
Posted: Sun Oct 14, 2012 8:01 pm
by adriangwatson
Hi guys. I've tried researching this question on here but still a bit confused....
I have a permanent Tyre Pressure red light warning come up on the DIS. I've checked the tyre pressures a couple of times now and the tyre pressures are fine.
Does this mean that the batteries in the tyre sensors are probably flat? I have an 06 model which I have only had for a year, and am not sure whether they have ever been replaced. Is there any way I can easily check?
Does it make most sense to just take it to an authorised dealer or am I best off just buying some new sensors online and getting a tyre
Shop to fit them?
Thanks for any advice
Re: Tyre Pressure warning errors
Posted: Sun Oct 14, 2012 9:09 pm
by D8vil
Have you reset the pressures in the computer menu ?
Posted: Sun Oct 14, 2012 9:18 pm
by adsgreen
Vag Com should tell you the error code but yes, likely the batteries are flat.
Posted: Sun Oct 14, 2012 10:19 pm
by adriangwatson
D8vil wrote:Have you reset the pressures in the computer menu ?
Hi, I'm not sure if I can because the red light seems to block out the functionality on the DIS.
Posted: Mon Oct 15, 2012 7:25 am
by GLOL
You can - I had this at the weekend. Just follow the instructions in the handbook to reset the pressures to the current value. Fixed my red warning sign...
Posted: Mon Oct 15, 2012 8:25 am
by alex020869
Anyone know if the sensors are expensive to replace?
Alex
Posted: Mon Oct 15, 2012 9:17 am
by adsgreen
alex020869 wrote:Anyone know if the sensors are expensive to replace?
Alex
80-100 quid each plus fitting and possibly valves.
Posted: Mon Oct 15, 2012 9:41 am
by alex020869
adsgreen wrote:alex020869 wrote:Anyone know if the sensors are expensive to replace?
Alex
Can the batteries be replaced or are they sealed units?
Alex
Posted: Mon Oct 15, 2012 5:26 pm
by PetrolDave
alex020869 wrote:Can the batteries be replaced or are they sealed units?
They're sealed units.
Posted: Mon Oct 15, 2012 5:34 pm
by adriangwatson
GLOL wrote:You can - I had this at the weekend. Just follow the instructions in the handbook to reset the pressures to the current value. Fixed my red warning sign...
Thanks, will give it a go. Fingers crossed. Having to spend £400+ on tire pressure sensors seems pretty punchy.....
Posted: Mon Oct 15, 2012 5:41 pm
by PetrolDave
adriangwatson wrote:Having to spend £400+ on tire pressure sensors seems pretty punchy.....
VCDS can tell you which of the sensors have dead batteries.
Posted: Mon Oct 15, 2012 5:54 pm
by spikeyboy101
i keep getting a yellow flat tyre symbol with a line through it - comes on for a while and goes off.
Tyres are always ok on pressures - diagnostic just gives a general error and doesnt point the finger at anything particular - any ideas ?
Posted: Mon Oct 15, 2012 5:56 pm
by chunky79
Think yours is turned off then.
Posted: Mon Oct 15, 2012 6:08 pm
by PetrolDave
spikeyboy101 wrote:i keep getting a yellow flat tyre symbol with a line through it - comes on for a while and goes off.
Try looking at the measuring blocks, that's where the details of pressure, temperature and battery voltage can be seen for each tyre.
Posted: Sat Oct 20, 2012 5:26 pm
by adriangwatson
Thanks for the advice - I reset the values and it seems to have done the trick.
