Oil cooler
Posted: Wed Oct 10, 2012 12:13 pm
by Gazzaton
Driving home last night and oil pressure warning light came on, was driving over the Kingston bridge (Glasgow) so wasn't able to pull over as quickly as would have liked. Into the garage this morning and they confirmed what I thought had happened, oil cooler and pipes burst due to corrosion. They're going to put a bridge pipe in first so, they can fill it with oil and make sure there's no damage to the engine (fingers crossed).
My question is, is there replacement pipes and connections that you can get that stop the corrosion ie. the same metal as the oil cooler?
Re: Oil cooler
Posted: Thu Oct 11, 2012 7:39 am
by GlenRS
I just replaced my lower oil pipe ( cooler and upper hose were fine) after I fitted the new hose I sprayed it all over with white grease on the exposed end where it corroded before.
Re: Oil cooler
Posted: Thu Oct 11, 2012 10:23 am
by mc72
I posted about replacing the pipes a few weeks back and have now found that the cooler connections are corroded away so it'll need changed anyway. An expensive job all in.
Re: Oil cooler
Posted: Fri Oct 12, 2012 4:58 pm
by CRSRS
Mine was in Perth Audi a couple of months ago and the tech said there was evidence of corrosion and should do sooner rather than later. Where did you take it in Glasgow? Are they replacing cooler as well as pipes?
