Clutch pedal won't work
Posted: Sat Sep 22, 2012 7:29 pm
by j-marksie
Driving the rs today, went to change gear from 2nd to 3rd and it wouldn't go into 3rd. Took my foot off the pedal and the clutch pedal wouldn't return :( nursed it home (luckily I was nearly home). It will still drive just won't engage the clutch!? Anyone got any ideas? I imagine it will be expensive :( :(
Re: Clutch pedal won't work
Posted: Sat Sep 22, 2012 7:38 pm
by Spaceman_RS4
Quick search gave me this
http://forum.rs246.com/viewtopic.php?f= ... ck#p497177
Poss clutch return pipe?
Posted: Sat Sep 22, 2012 8:18 pm
by j-marksie
That's talking about a heavy clutch, where as I think mine has been ok until today!? The pedal won't do anything? I take it that's it's not a clutch cable on these!? Seeing as you said return pipe?
Posted: Sat Sep 22, 2012 9:31 pm
by Spaceman_RS4
There was a bit in there about the clutch sticking down and not getting gears something to do with a faulty return pipe. Dunno if it s was after they got hot have you been back out try once cool bud?
I'd search the return pipe bit.
Posted: Sat Sep 22, 2012 10:14 pm
by j-marksie
Ah right sorry didn't see that bit, I was that pissed off I've walked away from it tonight but will try it in then morning to see if it works. If so then could be that faulty return pipe! Fingers crossed, does Audi cover it as a recall?
Posted: Sat Sep 22, 2012 11:28 pm
by Spaceman_RS4
No idea bud I'd never heard of it till I searched tonight, doubt it tho unless you have extended warranty you could try.
Posted: Sun Sep 23, 2012 2:05 am
by sonny
If the car wont go into gear (due to hydraulic clutch), make sure engine is turned off, select gear then start the engine, the car should be able to be driven in that gear, this should be able to get the car onto a low loader or elsewhere.
Sounds like the Clutch return pipe, will most likely need new clutch and possible flywheel...and most certainly a return pipe.
Posted: Sun Sep 23, 2012 8:20 am
by j-marksie
I take it that the return pipe comes from the thrust, through the bell housing to the slave cylinder? Therefore you would have to split it to get to it!? I've got a car lift, can you remove gearbox from underneath? Or is it engine out job? A lot of people talk about putting alternative clutches can anyone recommend any? Thanks for all your help by the way!
Posted: Sun Sep 23, 2012 9:50 am
by Spaceman_RS4
A quick bit I read said the return pipe was a simple job so I'd doubt it's box out I'd research changing that first
Posted: Sun Sep 23, 2012 10:15 am
by j-marksie
Just tried it again this morning and still no different clutch pedal goes to the floor, really hard to push about an inche from the bottom of travel. And I have to return it by pulling it back.
Posted: Sun Sep 23, 2012 10:37 am
by Dal
j-marksie wrote:Just tried it again this morning and still no different clutch pedal goes to the floor, really hard to push about an inche from the bottom of travel. And I have to return it by pulling it back.
Any fluid on the ground ? Have you checked the reservoir to see if its full ?
Posted: Sun Sep 23, 2012 2:11 pm
by watts6087
That is what happened to me on my rs. i needed and new clutch and dual mass fly wheel £1500 fitted.
Posted: Sun Sep 23, 2012 4:08 pm
by j-marksie
Still got clutch fluid in the resivoir
