Page 1 of 5
DRL bulb replacement....
Posted: Thu Jul 19, 2012 6:09 pm
by vestax32
I purchased some PIAA bulbs to replace my yellow DRL bulbs, but went to fit them this afternoon and it seems its not as easy as I thought?! Whats the best way to get to them, it seems like a right basta*d!!!
Posted: Thu Jul 19, 2012 6:13 pm
by brn7y
There is no easy way, apart from removing the lights.
If you have hands like shovels your are off to a bad start.
Re: DRL bulb replacement....
Posted: Thu Jul 19, 2012 8:12 pm
by MikeFish
It's not easy but possible. The more you do it the easier it becomes as you kinda know where to twist your hand and how much it hurts to do the job. Drivers side is much harder.
Posted: Thu Jul 19, 2012 8:15 pm
by MikeFish
PS, the first time I did it I the original bulb came out before I got the holder out the back of the lamp. The more I tried to grab it the further in it went. Needless to say, it is still in there, so be careful as you remove it.
Posted: Thu Jul 19, 2012 8:18 pm
by brn7y
MikeFish wrote:PS, the first time I did it I the original bulb came out before I got the holder out the back of the lamp. The more I tried to grab it the further in it went. Needless to say, it is still in there, so be careful as you remove it.
Take it there were some curse words used!
Posted: Thu Jul 19, 2012 8:33 pm
by MikeFish
Yeah, I tried to hook it out with a wire coat hanger but it was no good, the damn thing is still rattling around in there.
I have done it quite a few times now as Im trying to find some LED lamps that dont give errors. I am assuming that vestax32 doesnt need help with removing bits to get access but is only having trouble with the actual bulb removal. Half the battle is knowing which way to twist the lamp holder.
Posted: Thu Jul 19, 2012 8:53 pm
by j1sgo
It is fiddley and only acheived using the tips of your fingers, right pain.
Mikefish - Can you not fish the original bulb out using a magnet?
Posted: Thu Jul 19, 2012 8:54 pm
by Stoo.
Take the light out?
Posted: Thu Jul 19, 2012 9:43 pm
by vestax32
Which way do you turn the bulb holder then?
Posted: Thu Jul 19, 2012 9:45 pm
by vestax32
Posted: Thu Jul 19, 2012 9:49 pm
by MB2
Start on the drivers side as that is the easiest in terms of access... If you look at the font of the bulb holder you will see the cut-outs/shapes this will show you which way to turn it - likewise when you put it back use a torch to ensure the holder is lined up with the cut-outs as the bulbs fall out from excessive turning of the holders.
To get the bulb out I used a straightened out oat hanger with some double-sided tape on it was actually very easy to fish out or I got very lucky as thought was going to be a bumper/light off job.
Posted: Thu Jul 19, 2012 10:55 pm
by MikeFish
i tried the coat hanger but without the double sided sticky tape. i pushed it so far in that i cant even see it now, think it has gone over to join the headlamp.
i found the drivers side much harder to to because of a radiator / air con (cant rememebr which, but pretty sure it was radiator) hose is right in the way. I tried to remove it but that seemed harder than denting my hand and forcing just enough finger in (that sounds a bit rude).
Posted: Fri Jul 20, 2012 11:01 am
by gilford
Which bulbs have you replaced them with, more "xenon" looking ones? Do they bang out errors?
Would like to do this myself but can't seem to find a decent bulb without errors? I'm not keen on the yellow OEM ones so never use my DRL's!
Posted: Fri Jul 20, 2012 6:09 pm
by vestax32
These are the best non LED ones;
http://www.ebay.co.uk/itm/110833383119? ... 480wt_1180
I have just fitted mine and they don't throw up any warnings and look a hell of a lot better than the oem ones.......
Posted: Fri Jul 20, 2012 6:27 pm
by brn7y
That's the ones I use.
Also have these as sides.
http://www.ebay.co.uk/itm/XENON-BULBS-U ... 1c0fc02e4d
I also have these as fogs
http://www.hoen-usa.com/fog.htm
These as number plate bulbs.
Höen 4,000k direct replacement incandescent 36mm
http://www.hoen-usa.com/licenseplate.htm
All bulbs so no errors and great performance so far.
