Page 1 of 2
Need info asap before I leave deposit on rs4
Posted: Wed Feb 29, 2012 5:38 pm
by moglie
Thanks in advance for any advice....
Re: Need info asap before I leave deposit on rs4
Posted: Wed Feb 29, 2012 5:42 pm
by Timster
Hello and welcome to the forum.
FON.
Maybe do a couple of searches on FBSW (flat bottom steering wheel).
Posted: Wed Feb 29, 2012 5:44 pm
by P_G
There are a few on here that have swapped the wheel you have to the TT / R8 flatbottomed multifunction wheel but you cannot straight swap the one you have for the RS4 standard wheel. More or less desirable, that has been much debated on here including buckets vs. Recaro comfort seat but if the car has the right spec otherwise and you can live with the different wheel then it shouldn't stop you buying the car. But if you are asking about swapping it out then maybe that answers that question anyway.
As for costing more, can't say for sure but if it was it's not by much, i.e. hundreds of pounds rather than thousands.
FON
Posted: Wed Feb 29, 2012 5:54 pm
by Pie
Posted: Wed Feb 29, 2012 7:35 pm
by DazN
I swapped mine, took about 10 minutes. Wiring loom depends on the airbag, not the wheel.
Oh and
FON
Posted: Wed Feb 29, 2012 9:34 pm
by Adam
They fit that wheel as standard when Bluetooth option was selected with cradle in armrest (so you could control phone from SW)
I would not touch an RS4 without the desirable FBSW, get the garage to swap them over at their cost
Posted: Wed Feb 29, 2012 10:25 pm
by moglie
Thank you everyone for the replies.
Posted: Wed Feb 29, 2012 10:49 pm
by MB2
I think adding the RS4 FBSW and making the buttons work would be very tricky, as the S button on "your" car is routed to the dash at the moment. The TTRS wheel will keep the functionality of the MFSW the car currently has + the S button on the dash + give you the RS look you want with simple fitment, so I think the salesman is 1/2 correct.
Posted: Thu Mar 01, 2012 9:13 am
by adsgreen
Two options.
Option 1 - fit original rs4 fbsw. Sport button on dash Wouk remain but not function. You woul need to update the cars configuration using
Vag Com and you'd lose the additional controls provided by the mfsw (volume, radio etc)
Option 2 - fit tt-RS fbsw which replaces the mfsw controls like for like and I don't believe requires a software change. Sport button remains functional on the dash.
Buttons now days are driven burly software rather than physical wiring so although the button on the dash is currently sport it doesn't really matter.
Posted: Thu Mar 01, 2012 9:44 am
by Jules
This is not a big job,mine has had the FBSW retro fitted and all buttons work perfect,inc sport.
These wheels are fitted to loads of cars inc my last 2 a3's
Expect to pay about £550 for wheel inc airbag
Posted: Thu Mar 01, 2012 12:07 pm
by moglie
Thank you all once again. So just to confirm the audi ttrs flat bottomed steering wheel or the r8 flat bottomed steering wheel will fit directly onto the rs4 I'm looking at without any problem and still offer the same multi functions and not require software updates etc??
Posted: Thu Mar 01, 2012 12:19 pm
by Jules
moglie wrote:Thank you all once again. So just to confirm the audi ttrs flat bottomed steering wheel or the r8 flat bottomed steering wheel will fit directly onto the rs4 I'm looking at without any problem and still offer the same multi functions and not require software updates etc??
Its pretty much plug and play,but i would defo wait and source the proper rs4 one as it has the brushed polished bottom section,but
others will fit,ie tts,s3,etc,also if you go for the rs and want the sport button to work im sure that will need a feed from the
dash button.
Maybe you will need vagcam aswell to delete the airbag light once its been swapped,im sure someone close to you will have one
if you dont.
I even have friends running them in mk4s etc.
Posted: Thu Mar 01, 2012 1:36 pm
by paime
Posted: Thu Mar 01, 2012 2:03 pm
by gilford
paime wrote:What does FON mean?!?
F**K OFF NEWBIE
I've had it, a lot.................
Posted: Thu Mar 01, 2012 2:59 pm
by Boggle73
Hahaha !
