Page 1 of 2
Top speed on the B7.
Posted: Fri Nov 18, 2011 10:20 pm
by quattrosteph
What is the top speed on a B7 with the limiter and without limiter?
Re: Top speed on the B7.
Posted: Fri Nov 18, 2011 11:51 pm
by wellzieRS4
ive had 170
Posted: Sat Nov 19, 2011 2:34 am
by sonny
I think I answered this on another forum. But will post again. I saw 180mph on speedo, so that's around 173ish GPS.
MRC had run bottomed out RS4s at 193 due tot he limitations of the 6th gear.
So for me, 180 speedo, limiter removed.
Posted: Sat Nov 19, 2011 11:38 am
by PetrolDave
quattrosteph wrote:What is the top speed on a B7 with the limiter and without limiter?
quattro gmbh do not carefully calibrate the 155 limiter, in reality many people have reported seeing a GPS verified 168 with the limiter.
Posted: Sat Nov 19, 2011 1:49 pm
by S4Player
193 car won't go any faster until there's a new 6th gear made which is in the pipeline
Posted: Sat Nov 19, 2011 2:33 pm
by PetrolDave
Dannyrs4 wrote:until there's a new 6th gear made which is in the pipeline
Will that give a higher mph per 1000rpm? Even a standard RS4 needs a higher 6th IMHO (or a 7th gear).
Posted: Sat Nov 19, 2011 2:37 pm
by Brooner
Possibly why the RS5 has 7 gears?? wonder what that would be flat out?
Posted: Sat Nov 19, 2011 4:16 pm
by ArthurPE
imo top speed is limited by drag and power ~ 180-185
a different gear won't help...the car is drag limited....at peak power ~7500 rpm...you have less power >7500
180+ is pretty fast though
Posted: Sat Nov 19, 2011 4:59 pm
by S4Player
Sorry Arthur as much as always agree with most of your opinions I feel your wrong here reason being I look at my s4 on a standard box it will run 191 tops but with a modified 6th it will run 215 on a long enough strip. So if we modify a b7 box 6th ofcourse It will run more than 193 it will top 200mph
Posted: Sat Nov 19, 2011 5:01 pm
by S4Player
Also your 180-185 is wrong I've all ready had mine at 193mph
Posted: Sat Nov 19, 2011 5:41 pm
by ArthurPE
7500 is ~ 180-185 mph
power decreases after that, so you will go slower...you hit the 'wall'
now lets look at the thrust
torque = 5252/7500 x 420 ~ 295 lb ft
at the wheels ~ 295 x 4.11 x 0.78 / 1.08 ~ 870 lb (force)
now let's say you change the 6th to 0.72 from 0.78, in theory you should move 7500 rpm to 0.78/.72 x 185 ~ 200
but now you have only 295 x 4.11 x 0.78 x / 1.08 ~ 808 lb (force)...you can't go faster with less force
this does not factor driveline loss, friction or slip for tires, drag
in fact some cars go faster in 5th than 6th becasue of this
here's a pretty good calculator...the 60-120 times are spot on to the magazine tests...
I entered the RS4 specs, top speed ~185 (not sure if tire slip is factored 2-3% loss)
give it a shot http://vlsicad.ucsd.edu/~sharma/Potpourri/perf_est.html
a car with stock gearing that can move the HP peak up the power band a few hundred rpm could get another 3-4% speed 5 mph or so...
Posted: Sat Nov 19, 2011 6:07 pm
by ArthurPE
another way to look at it power required = power loss drag + power loss friction + power req to accel (we can ignore accel since we are a constant top speed...)
this by no means is exact, but close for order of magnitude evaluation, std equations Bosch and others...pretty typical
speed = v = 180 mph
wt ~ 4100 ~ 3900 + some stuff (like the driver)
HP drag = v^3 x Cd x A /151130 = 180^3 x 0.31 x 23.36 / 151130 ~ 280 HP (the Cd and A are from the sportauto supertest)
HP friction = 0.015 x wt x v / 375 ~ 0.015 x 4100 x 180 / 375 ~ 30
total 310 HP....and this is pretty close to what a healthy RS4 will deliver to the wheels on a dyno
190 mph ~ 360 wHP
Posted: Sat Nov 19, 2011 9:20 pm
by S4Player
My car was supercharged at the time so that would have played a factor surely
Posted: Sat Nov 19, 2011 10:25 pm
by ArthurPE
8000 rpm w/3% slip is 187 mph with stock gearing
gents, 180+ mph is fast...a 997 Turbo can 'only' do 192-193 (as verified in several tests)...it has much more torque...
I'd be content with being able to cruise 140-150 range without fear of loss of life (due to a stupid driver) or license...
the oem tire is rated Y or 300 km/hr ~ 186 mph,,,,Audi would not put a tire on the car lower than it's unrestricted top spped...
not that you could sustain that speed for long...
there are higher ratings (Y) in parenthesis is rated in excess of 186
Posted: Sat Nov 19, 2011 10:45 pm
by ShaneyB
183 on GPS and ran out of road.
No limiter.
