Page 1 of 2
Rough running when cold
Posted: Sat Sep 17, 2011 11:57 pm
by spikeyboy101
Hi guys,
My car has been running a bit rough when cold - spoke to Audi about it when i had the coil packs done, but typically of Tonbridge Audi they wernt keen on looking at the software version on the car or doing the update to SW0090
Now the temps are dropping a bit the rough running is worse, so going to speak to Tonbridge Audi again and instist it is done, however a couple of questions:
1) is this done free by Audi or is there a charge normally ?
2) Going to be getting a AMD remap in a couple of weeks (once the Milly is in stock) will the AMD remap cure the rough running when cold, or do i still need the SW0090 update, and to be done prior to the AMD map ?
Finally when speaking to AMD about their map they said it doesnt as standard remove the torque limit in gears 1, 2 and 3 but they can remove if i wish, however they said it could damage the gearbox - should i have any fear it will damage the gearbox ? or is it safe to have the torque limits removed ?
Thanks guys.
Re: Rough running when cold
Posted: Sun Sep 18, 2011 9:36 am
by ShaneyB
Spikey,
100% get the software update before the remap as the update will clear your map back to stock.
Audi will charge you for anything.
Not sure if the remap will cure the rough running.
Had my map for 6 weeks with no torque limiter and no issues as yet.
Good luck mate.
Posted: Sun Sep 18, 2011 10:04 am
by PetrolDave
You normally have to give an "acceptable reason" to get the 0090 SW update - smoky starts and rough running when cold are usually the "magic words".
Posted: Sun Sep 18, 2011 12:54 pm
by Timster
PetrolDave wrote:You normally have to give an "acceptable reason" to get the 0090 SW update - smoky starts and rough running when cold are usually the "magic words".
..... and don't forget the word "kangaroo-ing" as well.
Plus what Dave said.
Posted: Sun Sep 18, 2011 3:06 pm
by spikeyboy101
Thanks guys - will use the magic words (although these are my cars symptoms anyway)
Will see what tonbridge audi say.
Posted: Wed Sep 21, 2011 8:49 am
by Revolution
I had the SW0090 recall done, plus new coil packs and plugs and mine still runs rough when cold.....no faults on Vagcom either......pain in the bum :audibash:
Posted: Wed Sep 21, 2011 12:29 pm
by PetrolDave
Revolution wrote:I had the SW0090 recall done
It's not a recall (those are only for safety issues and organised through VOSA http://www.vosa.gov.uk/vosa/apps/recall ... sp?tx=VOSA), and it's not even a Workshop Campaign as it's an "on request" free upgrade - provided certain conditions are met.
Posted: Wed Sep 21, 2011 12:47 pm
by Revolution
...good point, learn something new everyday. - still a pain though
Posted: Wed Sep 21, 2011 4:22 pm
by PJC
Revolution wrote:...good point, learn something new everyday. - still a pain though
Must be that North East air............
Posted: Wed Sep 21, 2011 4:33 pm
by Revolution
LOL...it is fresh...and clean... :thumbs:
Posted: Wed Sep 21, 2011 5:37 pm
by P_G
Revolution wrote:I had the SW0090 recall done, plus new coil packs and plugs and mine still runs rough when cold.....no faults on VAGCOM either......pain in the bum :audibash:
Too rich a mixture until oil temp reaches 60 degrees, then you'll find it runs smoother so I would suspect a mixture program associated with the engine rev limiter protection program. I also notice my fuel gauge improves marginally after this phase.
Posted: Wed Sep 21, 2011 7:46 pm
by Revolution
nice one P_G
next job to tackle :biggrin3:
Posted: Wed Sep 21, 2011 9:46 pm
by sonny
As above. Get SW0090 then AMD remap.
Posted: Thu Sep 22, 2011 9:14 am
by Revolution
sonny wrote:As above. Get SW0090 then AMD remap.
"cough" had SW0090 and Revolution Remap next... :thumbs:
Posted: Thu Sep 22, 2011 10:39 am
by sonny
Also try a injector cleaner such as Redex or Wynns, give the car a service (if it needs it) also inspect the air filter.
The AMD remap I am guessing will be a generic remap and not a custom one (could be wrong).
