Tyre pressure sensors
Posted: Mon Aug 15, 2011 9:02 am
by Jules
Hi all
Is it possible to turn off the tyre pressure sensors,i am about to change the alloys but want to keep the sensors
on my old wheels,or can new ones just be purchased.
If so how much are these ?
Re: Tyre pressure sensors
Posted: Mon Aug 15, 2011 9:53 am
by adsgreen
I think but not 100% that the TPMS can be disabled using
Vag Com.
New ones aint cheap - IIRC they are about 70-100 quid a corner.
Posted: Mon Aug 15, 2011 10:01 am
by RSKiwi
Jules wrote:Hi all
I am pretty sure you can but you may need to check insurance fine print incase you ever have an accident due to flat/low pressure tyre. They may not take kindly to a standard piece of equipment being turned off.
Personnaly I am getting pretty close to putting my fist through the dash with the number of false warnings I get and how hopeless Audi are at fixing the problem....sorry
Posted: Mon Aug 15, 2011 10:18 am
by leont
I did it on mine using
Vagcom using the process below. It basically removes it from the DIS menu altogether.
17 - Instruments - Adaptation - Channel 61. Subtract 512 from whatever value you find and save.
Posted: Mon Aug 15, 2011 10:41 am
by Jules
leont wrote:I did it on mine using VAGCOM using the process below. It basically removes it from the DIS menu altogether.
I'll give that a try
Many thanks
Posted: Tue Aug 16, 2011 5:21 pm
by pisquano
really? mine had been disabled by the previous owner (without telling me...bloody bastard) and only found out @ MRC,
and I really want to bring it in @ Camberley
Posted: Tue Aug 16, 2011 6:26 pm
by PJC
Are you all now sorted then Fed?
Posted: Wed Aug 17, 2011 5:47 am
by Brooner
Yep switch mine off after changing all the sensors and the aireal and stop got error signals the only other thing left to change is the control unit £400 form Audi so ill leave it for the moment
