Page 1 of 2
Wynns DIP3 Intake Cleaner
Posted: Fri Apr 08, 2011 7:35 pm
by P_G
I've decided to experiment with this stuff since my car is in for its service on Thursday and will have an oil change then The pertol treatment has worked so this will see if there is any additional benefit. I read the instructions and it looks like the suggestion is to spray in the air intake by removing the air filter, but would this not affect the MAF?
Is there an entry point after the MAF I could spray this in and if so, has somebody got an idiots guide diagram of can describe where to appl;y for this idiot?
Cheers.
Re: Wynns DIP3 Intake Cleaner
Posted: Fri Apr 08, 2011 9:18 pm
by scaghead
not sure how it was done, but andy 911 uk applied it to one of the motors at the rr day we went to at paramount maybe worth a pm
Posted: Fri Apr 08, 2011 10:08 pm
by ArthurPE
get some tubing that fits snug on the product nozzle
loosen the hose clamp after the afm and insert the tubing...
I think you are correct on not wanting to hose down the afm
Posted: Fri Apr 08, 2011 10:50 pm
by d10uug
I did this treatment a couple of months ago and it really did make a noticeable difference. It felt a lot sharper instantly, well with it .
I loosened the clip after the maf and put it in that way as I didn't want to risk any damage.
Dougie
Posted: Sat Apr 09, 2011 4:52 am
by kiwi_mtm
Posted: Sat Apr 09, 2011 8:42 pm
by scaghead
d10uug wrote:I did this treatment a couple of months ago and it really did make a noticeable difference. It felt a lot sharper instantly, well with it .
Dougie
i have used the petrol treatment and i am going to give the spray a go...the wynns gear does defo seem to work
Posted: Mon Apr 11, 2011 12:18 pm
by Stoffle32
Some of the guys in SA have used it...
They took off the intake pipe... Sprayed it down, while the engine is running at around 2000rpm...
Posted: Mon Apr 11, 2011 12:54 pm
by JackS4
Apologies for slightly daft question but is it just one spray treatment or two given RS has 8 lots of valves to treat rather than 4 lots in 4 cyl engines which I would expect is the larger market for this product ?
J
Posted: Mon Apr 11, 2011 1:24 pm
by P_G
It''s a good point. TBH with the Petrol Treatment I use it every 4-5k miles whereas it says every 10k Km's and will probably do the same with the spray which is supposed to be every 15k km's. Given I have never used it before I will probbaly try it this time and then prior to my next oil change in 5-8k miles time.
Posted: Mon Apr 11, 2011 1:25 pm
by P_G
Dougie
I gather you had someone modulating the throttle then whilst you sprayed it in?
Posted: Tue Apr 12, 2011 1:48 pm
by JackS4
I checked directly with Wynns in relation to my own question (1 or 2 applications for a V8).
I got a very quick and friendly response which is that if they are badly coked up use a second application.
When I queried about an oil change being required they where clear that it wasn't required as both the chemical and the dissolved deposits are combusted.
Also, the formula of the products (spray and fuel additive) have recently changed and are revised as follows:
· Aerosol is now Petrol EGR 3 - pn 29879
· Tank treatment is now Petrol Clean 3 – pn 29793
Now just need to figure out where I can actually get the stuff in Ireland....
J
Posted: Tue Apr 12, 2011 2:04 pm
by P_G
JackS4 wrote:I checked directly with Wynns in relation to my own question (1 or 2 applications for a V8).
J
Good answer if you know how badly coked up they are. Unless by borescope you'll be opening up the IM so may as well clean it by hand anyway!
Posted: Tue Apr 12, 2011 2:12 pm
by Stoffle32
Liqui Molly also do a similar Product, Im going to pick up a can this week and give it a try...
As for how do I know how clogged they are, I have no idea but couldn't hurt to try a can
http://www.liquimoly.co.uk/index.php?p= ... ails&id=27
Posted: Tue Apr 12, 2011 2:33 pm
by P_G
I will at some stage try their Toptech 4200 Oil given it is also supposed to have CB minimising properties.
Posted: Wed Apr 13, 2011 8:19 am
by JackS4
I should have been clearer - the advice by Wynns wasn't on the basis of knowing exactly how much CB there was but if symptoms of it where still there after 1 application - eg rough idle, lack of top end power etc.
Anyways, their recomendation was to use the intake cleaner at least once a year as a preventative maintenance exercise.
J
