Page 1 of 2
First gear difficult to engage when cold
Posted: Fri Feb 25, 2011 10:53 pm
by wolfgang
I've had this issue with several other cars and it was deemed to be normal. I find engaging first gear very difficult after a cold start. Is this normal on the RS4? Often I have to put it in second and then first. After 5-10 minutes it's fine.
RE: First gear difficult to engage when cold
Posted: Fri Feb 25, 2011 10:59 pm
by wellzieRS4
mine to
Posted: Fri Feb 25, 2011 11:02 pm
by neckarsulm
mine doesn't
Posted: Fri Feb 25, 2011 11:06 pm
by HYFR
nor mine (or my last)
Posted: Fri Feb 25, 2011 11:14 pm
by sonny
Gear linkage may need adjusting.
Posted: Sat Feb 26, 2011 1:58 am
by Timster
Sounds about right Sonny. I remember when viewing a vid on youtube for a short-shift kit, that the RS4 linkage was a bit trial & error to get right & ensure that 1st gear was a clean movement.
Just a couple of screw/torx adjustments from under the gearstick garter to put right.
(fiddly though)
Posted: Sat Feb 26, 2011 11:46 am
by PetrolDave
Don't forget it's a high torque gearbox so there are big heavy gears used for the lower gears, combine that with 90 viscosity gearbox oil and first gear is always going to be heavy to engage, especially when cold.
Re: RE: First gear difficult to engage when cold
Posted: Sat Feb 26, 2011 1:18 pm
by sonny
TimsterRS4 wrote:Sounds about right Sonny. I remember when viewing a vid on youtube for a short-shift kit, that the RS4 linkage was a bit trial & error to get right & ensure that 1st gear was a clean movement.
(fiddly though)
Yep when I had my OEM gear shift put back in last month, it took ages to get it balanced and "just right" think there is 3 points of adjustment but dont hold me to that. I was installing my GruppeM while the tech was doing my gear shift.
..and what PD says too, it could be a combination of things.
Re: First gear difficult to engage when cold
Posted: Tue Mar 08, 2011 10:31 pm
by wellzieRS4
Mine is spot on now, slides in smooth in any gear, it was the input shaft it needed greasing, it was sticking to the bearing. wot a difference sometimes i had to use a lot of force to select first gear now i can push it in with my finger
Posted: Tue Mar 08, 2011 10:53 pm
by wolfgang
wellzieRS4 wrote:Mine is spot on now, slides in smooth in any gear, it was the input shaft it needed greasing, it was sticking to the bearing. wot a difference sometimes i had to use a lot of force to select first gear now i can push it in with my finger
My car is going in for a coil pack check tomorrow. I'll mention the gear change to the dealer. How long did the work take?
Posted: Wed Mar 09, 2011 12:10 am
by lugars4
Isnt that a gearbox off job ? Did u have clutch work done at the same time?
Posted: Wed Mar 09, 2011 12:38 am
by pisquano
mine is pretty difficult (only 1st) when it's cold
works like a breeze once the car has warmed up
Posted: Wed Mar 09, 2011 1:12 am
by Steve_C
Same for me, difficult when cold but easier when warm (not completely easy though).
Posted: Wed Mar 09, 2011 11:15 am
by pisquano
I actually find the gearbox of the RS4 incredibly smooth and easy to operate, with the exception of when it's really cold!
this makes it such an easy car to drive you wouldn't expect from such a beast!
it's SO much better than, say, an E46 M3, which I found horribly stiff the few times I tried them
Posted: Wed Mar 09, 2011 11:41 am
by SR71
I had to leave it 11 mins once before I could get it into gear having left it outside in Switzerland for a week whilst snowboarding...
