Page 1 of 2
Dynamic/adaptive headlights
Posted: Tue Feb 08, 2011 8:11 pm
by wolfgang
According to one of my option codes, I have the following:
8Q5 = Headlight-range adjustment, automatic/ dynamic with dynamic bending light (AFS 1)
How can I tell that I have this?
In previous cars i've had I can see the beam levelling when I start the car. In my car I don't see anything happening other than the lights switching on.
RE: Dynamic/adaptive headlights
Posted: Tue Feb 08, 2011 8:26 pm
by adsgreen
If you go somewhere dark (or wait for night time) and park the front near a wall then when you switch on the lights they will do a little dance left/right and up/down.
Re: RE: Dynamic/adaptive headlights
Posted: Tue Feb 08, 2011 8:28 pm
by andre3k
adsgreen wrote:If you go somewhere dark (or wait for night time) and park the front near a wall then when you switch on the lights they will do a little dance left/right and up/down.
I have 8EC = Bi-functional headlight with gas discharge lamp, for driving on the left = Standard Xenons
For the record my car does this little dance on startup.
Posted: Tue Feb 08, 2011 8:29 pm
by m3vhf
I tested mine last night after i found i had this option on my car. Pulled up about 10m from a wall, full lock left then right i could see the lights changing direction.
Posted: Tue Feb 08, 2011 9:56 pm
by Macdaddy
What exactly is it tho?
Switched on the car outside the gym tonight and the lights went left/right up/down! Young girl coming out thought I was flashing my lights at her from the look she gave me lmao
Posted: Tue Feb 08, 2011 10:01 pm
by sonny
m3vhf wrote:I tested mine last night after i found i had this option on my car. Pulled up about 10m from a wall, full lock left then right i could see the lights changing direction.
Strange as I thought the adaptive lights only worked once the car was mobile and after a certain speed.
Posted: Tue Feb 08, 2011 10:05 pm
by MB2
You can set them in VCDS to "showroom mode" at which point they move at 0 speed. I have adaptive lights & they dance at start up (quite noticeable) & can sometimes seem them move when driving down a country road at night but not sure how much is the lights & how much the actual car moving from steering input.
RE: Re: RE: Dynamic/adaptive headlights
by adsgreen
Ditto
Posted: Tue Feb 08, 2011 10:11 pm
by sonny
Mine does the start up sequence as well (so the car knows at which datum the set the light pattern) L-R-U-D. I love the adaptive lights, esp in misty lanes.
Posted: Tue Feb 08, 2011 10:44 pm
by wolfgang
Okay, if I park facing a reflective surface then what exactly do I have to do to notice this 'dancing' effect? Do I just turn on the dipped headlights or the main beam? Also, do I need the engine running when I turn the lights on to notice the 'dancing'? I have no warning or fault lights on the dash so I presume things are working but I don't notice that effects that you guys are describing!
Posted: Tue Feb 08, 2011 10:50 pm
by MB2
My headlights are on auto & when I start the engine (not the ignition) they do their little dance a few seconds after it fires up.
So I would guess lights on (dipped not side lights if not auto), ignition on, start the motor & the lights should "bust a move". I think if rapid on/off they don't repeat so try it from where you are normally parked if you can.
Posted: Tue Feb 08, 2011 10:59 pm
by Steve_C
My lights are on auto too and as I park in forwards into a darkish garage I see the dance every time I start the engine.
Posted: Tue Feb 08, 2011 11:07 pm
by andre3k
Just to emphasise my point, the dancing lights on startup are not an indication of adaptive lights.
If you're looking for confirmation of adaptive functionality then the showroom thingy mentioned above is prob more useful
Posted: Tue Feb 08, 2011 11:38 pm
by Ice_Coffee
I have self levelling only, (non AFS) headlights on my cab, mine only go up and down on start up, but I have purchased a pair of AFS from ebay, and so will be joining the rest of the dancing light mob soon :)
Re: RE: Re: RE: Dynamic/adaptive headlights
Posted: Wed Feb 09, 2011 12:37 am
by DuncS3
sonny wrote:Mine does the start up sequence as well (so the car knows at which datum the set the light pattern) L-R-U-D. I love the adaptive lights, esp in misty lanes.
Drive down some twisty roads and you should easily see your light beams move with the steering wheel once over a certain angle - its pretty cool as Sonny says
