Page 1 of 3
Best injector cleaner for RS4
Posted: Fri Jan 28, 2011 11:53 pm
by wolfgang
I want to run a bottle of injector cleaner through the fuel tank of my RS4. I bought the car with 51K miles on it so it's a fairly high miler. It's had nothing other than Shell V-Power since I bought it but I have no idea what fuel was used for the first 51K miles.
For those of you who have used fuel additives to clean the injectors and fuel system, what are your experiences with them and what, if any, benefits did you notice? Are they all much of a muchness?
RE: Best injector cleaner for RS4
Posted: Sat Jan 29, 2011 12:09 am
by Ice_Coffee
well if audi are to be believed, then strictly no other products than
"Fuel additive for petrol engines, available under - Part No.: G 001 700.03"
Posted: Sat Jan 29, 2011 12:24 am
by ArthurPE
I like LubroMoly
Posted: Sat Jan 29, 2011 12:27 am
by P_G
I use Winns DIP3 every 5k miles. I've tried a few and the car is more responsive on this than many other DI injector cleaners.
Posted: Sat Jan 29, 2011 1:03 am
by d10uug
P_G wrote:I use Winns DIP3 every 5k miles. I've tried a few and the car is more responsive on this than many other DI injector cleaners.
Hi PG do you have a link to where this can be bought, as I have heard good things about it but cant seem to find a seller.
Cheers for the help
Dougie
Re: RE: Best injector cleaner for RS4
Posted: Sat Jan 29, 2011 5:42 am
by madgreek
Ice_Coffee wrote:well if audi are to be believed, then strictly no other products than
My dealer gave me this:
I also occasionally use BG 44k, no sure if it's available over there. I tend to only use fuel additives before changing the oil as the detergent agents & deposits break down the oil.
Posted: Sat Jan 29, 2011 9:40 am
by P_G
Cheers for the help
Dougie
IIRC if you go to Winns website there is a dealer locator on it. I use Andrew Page motofactors in Newcastle for mine.
Posted: Sat Jan 29, 2011 10:14 am
by Brooner
d10uug wrote:P_G wrote:I use Winns DIP3 every 5k miles. I've tried a few and the car is more responsive on this than many other DI injector cleaners.
Cheers for the help
Dougie
i used my loacal garage the can order it and have it there in a couple of days as this is normaly a motor trade product i think
Posted: Sat Jan 29, 2011 11:40 am
by PetrolDave
I get Wynns DIP3 from a motor factor in Eastleigh.
Posted: Sat Jan 29, 2011 10:54 pm
by Ice_Coffee
If you decide to use the audi stuff these are the instructions, interestingly it also notes how to tell if you need to do this or not (provided you have VCDS)
Posted: Sun Jan 30, 2011 8:27 am
by A20LEE
I used to use it on my corrado and later found it caused the seals on the injectors to bond themselves to the head and injectors and had to have a whole new fuel rail as it was bent trying to get the thing off. I was told not to use it again, it was the slick 50 version i used every 6000 miles.
Posted: Sun Jan 30, 2011 10:12 am
by Ice_Coffee
A20LEE wrote:I used to use it on my corrado and later found it caused the seals on the injectors to bond themselves to the head and injectors and had to have a whole new fuel rail as it was bent trying to get the thing off. I was told not to use it again, it was the slick 50 version i used every 6000 miles.
And that is probably why we should stick to G17, regarding fuel additive.
Posted: Sun Jan 30, 2011 10:48 am
by P_G
Use what A20Lee, DIP3 or G17?
Posted: Sun Jan 30, 2011 12:24 pm
by klauster
I have never done this, do you think its worth me asking the dealership parts dept to give me some to try? What price should I expect to pay?
Posted: Sun Jan 30, 2011 2:23 pm
by Ice_Coffee
I would use G17 in combination with DIP 3 Aerosol as they do two different jobs, G17 cleans the injectors, DIP 3 aerosol reduces our coking problem, there is no need to use G17 unless you do the test with VCDS and fail it.
