Stuck exhaust valve
Posted: Sat Jan 22, 2011 2:48 pm
by jim1_6310
Sorry for asking this question again but i couldn't find a earlier thread.
Anyways as it says above one of the valves stuck on me yesterday and now i cant get it til open. is there much involved for getting them working again.
Thanks in advance
Jim
RE: Stuck exhaust valve
Posted: Sat Jan 22, 2011 4:21 pm
by sonny
Check that one of the vacuum hoses has not come off the rear solenoid flap. It is located next to the tail pipe, you will have to get under the car to look.
Re: RE: Stuck exhaust valve
Posted: Sat Jan 22, 2011 5:38 pm
by Dom81
sonny wrote:Check that one of the vacuum hoses has not come off the rear solenoid flap. It is located next to the tail pipe, you will have to get under the car to look.
Surely if the hose had come off, the valve would be stuck open?
Posted: Sat Jan 22, 2011 5:58 pm
by sonny
Yep your right. :oops:
RE: Re: RE: Stuck exhaust valve
Posted: Tue Jan 25, 2011 7:56 am
by jim1_6310
No hoses are still on it just doesn't want to open for some reason
Re: RE: Re: RE: Stuck exhaust valve
Posted: Tue Jan 25, 2011 8:18 am
by leont
jim1_6310 wrote:No hoses are still on it just doesn't want to open for some reason
I recently noticed both mine were stuck shut - it took quite a bit of force with a hammer and a long screwdriver to open them back up. I then sprayed the hinges quite liberally with lube. They closed back up again after a few days so I've done the mod to remove the vacuum hoses.
RE: Re: RE: Re: RE: Stuck exhaust valve
Posted: Wed Jan 26, 2011 7:44 am
by jim1_6310
so do you just leave yours open all the time now. Is there anywhere on here which tell you how to do this mod.
cheers jim
Posted: Wed Jan 26, 2011 9:01 am
by Ice_Coffee
some peeps do, it is a straight forward mod, remove Vacuum hoses ****PLUG VACUUM HOSES**** (Very important), cap off the lugs on the exhaust that the vacuum hoses went to, to stop excess debris entering.
DONE
PS for a moment there after reading your heading, I thought one of the exhaust valves in your cylinder head was stuck closed. I was thinking "thats going to be expensive"
Posted: Fri Jan 28, 2011 9:00 am
by jim1_6310
cheers i might try at if i cant get it til open again
