Page 1 of 2
Exhaust flaps & noise
Posted: Sun Jan 09, 2011 7:04 pm
by leont
After reading several posts on here about the exhaust flaps I tested them earlier. The flaps stay closed at all times, S button on or off. I even got the missus to give it some revs while I watched the flaps (and near choke me to death!) and no movement at all. I'm assuming there is a vacuum issue or maybe the flaps need lubricating.
The thing is when I'm driving the car and press the S button it definitely gets more vocal. I tried it yesterday on the motorway and instantly my passenger picked up on the extra noise (sounds fantastic).
Does this sound right? I had naturally assumed the flaps were in working order because of the noise with the S button on?
RE: Exhaust flaps & noise
Posted: Sun Jan 09, 2011 7:14 pm
by adsgreen
The flaps only open at idle.
After that there's some very strict rules in sport mode that dictate when they open.
Something like closed unless
- idle engine speed
- over 3k rpm
- 4th gear or higher
- over 30mph
Re: RE: Exhaust flaps & noise
Posted: Sun Jan 09, 2011 7:18 pm
by Ice_Coffee
adsgreen wrote:The flaps only open at idle.
- idle engine speed
- over 3k rpm
- over 30mph
and the whole lot does not turn on until the 7000RPM MAX sign has gone out !
67Deg C engine oil
RE: Re: RE: Exhaust flaps & noise
Posted: Sun Jan 09, 2011 7:22 pm
by leont
I took it for a run first so the 7K limit was gone - engine oil was in the 70's. Flaps closed when idling with S button on/off. What is confusing is the car is noiser when driving about with the S button on. Its as though the flaps work at speed, but not at idle. Unless there is another reason for the extra noise at speed with flaps closed?
Re: Exhaust flaps & noise
Posted: Sun Jan 09, 2011 7:29 pm
by PetrolDave
leont wrote:The flaps stay closed at all times, S button on or off.
At normal tickover rpm, even with a cold engine, the flaps should open when you press the Sport button and the exhaust noise will increase.
If they don't then IMHO that indicates a vacuum problem and/or stuck actuators.
RE: Re: Exhaust flaps & noise
Posted: Sun Jan 09, 2011 7:41 pm
by leont
If they donThanks - I'm going to lubricate them try tomorrow, next step trying the mod to keep them open at all times.
I've probably not been that clear in my post. What confuses the issue is that (assuming the flaps are closed permanently) why I get the extra noise when I press the S button on the move. If the flaps are closed where is it coming from? Is it just extra induction noise coming through from the air intake flap?
Posted: Sun Jan 09, 2011 7:56 pm
by adsgreen
Perhaps more vacuum available when the engine revs are higher??
Posted: Sun Jan 09, 2011 8:31 pm
by neckarsulm
good point
This is definitely correct as I have tested mine hot and cold when Birmingham Audi told me they were defective,£782 please (the tw4ts were wrong)
Re: RE: Re: Exhaust flaps & noise
Posted: Sun Jan 09, 2011 9:11 pm
by aidanjaye
good point
Agree - even stone cold - press S button and flaps will open and exhaust sounds deeper.
RE: Re: RE: Re: Exhaust flaps & noise
Posted: Sun Jan 09, 2011 9:52 pm
by Ice_Coffee
In that case I stand corrected
Posted: Sun Jan 09, 2011 10:00 pm
by ShaneyB
I thought 'S' mode was compulsory :-)
Posted: Mon Jan 10, 2011 8:01 pm
by Timster
Remember also, that if you have the 090 firmware... the initial revs will stay higher for longer, until they drop back to idle.
And as others have said.... it's not until they drop to idle, that the flaps will work (hot or cold).
Any joy yet?
Re: RE: Re: RE: Re: Exhaust flaps & noise
Posted: Mon Jan 10, 2011 10:57 pm
by aidanjaye
TimsterRS4 wrote:Remember also, that if you have the 090 firmware... the initial revs will stay higher for longer, until they drop back to idle.
Any joy yet?
Emm , dont think so.
Car running 09 firmware - coldstart, press S button on/off even when revs are up and you can here the flaps opening and shutting (engine tone).
RE: Re: RE: Re: RE: Re: Exhaust flaps & noise
Posted: Mon Jan 10, 2011 11:13 pm
by Timster
Erm, Yes so.
Start the car from cold ~ whilst engine still idling above 1k rpm ~ run out the back of your car (with torch if necessary) and check flaps. They'll be closed. Now press "S", you'll get plenty of other noises and rumblings (seat bolsters moving etc).... the flaps will still be closed however.
Wait a few seconds until the engine dies down too 800 rpm ish. Try the same ~ flaps will open and close with "S" button.
Posted: Mon Jan 10, 2011 11:24 pm
by neckarsulm
aidanjaye, Timster is correct, it has to be the normal idle speed for the S button to open the valves.
However, there is a noise, a bit like a repetitive clicking which someone says is unburnt fuel related, I have checked my exhaust flaps when it does this and they are closed still
