Page 1 of 2
Software version numbers clarification
Posted: Fri Dec 03, 2010 12:47 pm
by wolfgang
Are there two different software version numbers that are relevant to the RS4?
Is there an ECU map version number (latest being SW0090, I believe) and a separate nav software version (latest being SW0650, I believe)?
RE: Software version numbers clarification
Posted: Fri Dec 03, 2010 1:19 pm
by Christiaan
Yes,
My car (ECU) is running SW0090 but the Nav shows SW0050.
Posted: Fri Dec 03, 2010 1:55 pm
by sonny
Nav and ECU are different, there not the same thing.
Re: RE: Software version numbers clarification
Posted: Fri Dec 03, 2010 6:30 pm
by PetrolDave
sonny wrote:Nav and ECU are different, there not the same thing.
When I last counted it the "average" B7 RS4 has 38 different software based electronic modules - all of them having different software versions.
I very much doubt that your sat nav has SW version 0050 - that was released in 2004 and was up to version 0360 before the first B7 RS4 came off the production line.
I think it probably says 0650 not 0050...
Posted: Fri Dec 03, 2010 6:44 pm
by sonny
PetrolDave wrote:sonny wrote:Nav and ECU are different, there not the same thing.
I know.
Posted: Fri Dec 03, 2010 6:46 pm
by PetrolDave
sonny wrote:I know.
I know that you know but wolfgang and Christiaan clearly don't...
RE: Re: RE: Software version numbers clarification
Posted: Fri Dec 03, 2010 10:54 pm
by Christiaan
Dave, may I beg for your forgiveness, as I was slightly incorrect in my Nav software number. It is not 0050, as you know (you are always right) but in fact it was 0550.
I am also very sorry for not knowing that there are 38 different electronic modules.... however.... Wolfgang asked....
"Is there an ECU map version number (latest being SW0090, I believe) and a separate nav software version (latest being SW0650, I believe)?"
... to which I answered Yes.... which, on a very simple level is correct.
Re: RE: Re: RE: Software version numbers clarification
Posted: Sat Dec 04, 2010 10:54 am
by PetrolDave
Christiaan wrote:It is not 0050, as you know (you are always right) but in fact it was 0550.
Which means you're using a very old map on your sat nav, 2007 I think?
The 2011 maps are just becoming available in Europe, which means they should appear in the UK in about February.
RE: Re: RE: Re: RE: Software version numbers clarification
Posted: Fri Dec 24, 2010 4:03 pm
by fletchie55
Just found this thread and wondered about the software versions, if you discover you have the old one, can you just go in to Audi and ask them to change it? Is it something they automatically do (or should do!) at the service, and is it chargeable?
Re: RE: Re: RE: Re: RE: Software version numbers clarificati
Posted: Fri Dec 24, 2010 4:36 pm
by PetrolDave
fletchie55 wrote:Just found this thread and wondered about the software versions, if you discover you have the old one, can you just go in to Audi and ask them to change it? Is it something they automatically do (or should do!) at the service, and is it chargeable?
Going up as far as 0080 should be done automatically when serviced.
0090 is on request only, and only if you say the right things (cold start is really rough and driving for the first few miles is lumpy too).
RE: Re: RE: Re: RE: Re: RE: Software version numbers clarifi
Posted: Fri Dec 24, 2010 4:52 pm
by fletchie55
Cool thanks Dave, it actually is a little lumpy when its cold so I'll pop in and see what they say. How long does it take them to do change the SW over? Guess I better check I dont have the newer version first or I'll look even more stupid!
Re: RE: Re: RE: Re: RE: Re: RE: Software version numbers cla
Posted: Fri Dec 24, 2010 7:12 pm
by PetrolDave
fletchie55 wrote:How long does it take them to do change the SW over?
Not had it done separately, only as part of a service, so I don't know how long it takes to download it to the car. Remember the RS4 has 2 engine ECUs that both need updating.
RE: Re: RE: Re: RE: Re: RE: Re: RE: Software version numbers
Posted: Fri Dec 24, 2010 8:08 pm
by wolfgang
It takes around 30 minutes. I had my update to SW0090 earlier this week.
Posted: Fri Dec 24, 2010 9:25 pm
by RS6chris!
Christiaan wrote:Dave, may I beg for your forgiveness, as I was slightly incorrect in my Nav software number. It is not 0050, as you know (you are always right) but in fact it was 0550.
Christian,
Dont you know you have to know your facts on RS246...??? Dont dare make a simple mistake or you will get shot down!!!!
Dont fret mate we arent all "experts"...lol...
Posted: Fri Dec 24, 2010 11:50 pm
by Rick_RS4
i had a look through my reciepts and found that my car might have been superchipped, and audi couldnt do the upgrade because of this, should i remove the superchip is this a problem? cold starts arnt the best at the min
