b7 rs4 recall - "oil pipe"
Posted: Thu Jul 08, 2010 9:31 am
by goron59
Just had my local dealer call for a recall item: "oil pipe."
No more detail than that - anyone had this already, or knows any more info?
Posted: Thu Jul 08, 2010 9:53 am
by aidanjaye
Had it done a few weeks ago - seems its just checking of pipes and clips. Mines was ok.
Posted: Thu Jul 08, 2010 1:50 pm
by Nib
The braded pipes that run to the oil cooler, which is in front of all the other coolers, can sometimes chaff leading to (possible) long-term failure. Dealers usually put a plastic ‘hose-holder’ between the pipes to prevent this.
Whilst they’re in the area the tech will also check for leaks from the cooler/hose unions and if found will probably replace hoses & cooler, as the hoses don’t come away easily. It’s a front-off job.
It's not a bad idea to then coat the unions with engine wax to prevent future corrosion before putting the front back on.
Posted: Thu Jul 08, 2010 2:50 pm
by goron59
Thanks for the info !
Posted: Thu Jul 08, 2010 7:18 pm
by PetrolDave
I've said this before and I'll say it again - items like this are NOT a recall (which is coordinated by VOSA and is for safety items ONLY), it is a Service Campaign and is OPTIONAL but advisory.
I've just had all the outstanding Service Campaign work done on my RS4 (paid for by the extended warranty), as well as a DRC replacement due to leaking front shock absorbers.
Posted: Thu Jul 08, 2010 7:39 pm
by goron59
[quote="PetrolDave"]IYes, but the dealer refers to it as a "recall item," so that's how I call it.
Posted: Fri Jul 09, 2010 11:53 am
by drcarrera
PetrolDave wrote:I've said this before and I'll say it again - items like this are NOT a recall (which is coordinated by VOSA and is for safety items ONLY), it is a Service Campaign and is OPTIONAL but advisory.
Dave,
what other SC work did you have done (if you don't mind me asking).
Posted: Fri Jul 09, 2010 1:40 pm
by P_G
PetrolDave wrote: as well as a DRC replacement due to leaking front shock absorbers.
Your GenII finally succumbed? How are you finding it now it has Gen III on it?
Posted: Fri Jul 09, 2010 2:56 pm
by Sims
PetrolDave wrote:...
DRC on extended warranty, or Audi goodwill?
Posted: Fri Jul 09, 2010 7:16 pm
by PetrolDave
drcarrera wrote:what other SC work did you have done (if you don't mind me asking).
1) Oil pipe corrosion
2) fuel pressure sensor
3) spare wheel well cracking
Plus SW update to 0090, and DRC replacement.
All paid for by Audi UK despite my car being 3 years 11 months old.
Posted: Tue Jul 13, 2010 2:43 am
by Oli133
hey bud
I had mine done just after the oil pipes split!! luckily i was only doing a short ttip so noticed a huge oil patch on the drive a few hrs later!
best nit was it was ion for a service 3 days later so they done it and replaced the oil free of charge! 289 quid for a service! now thats value!
happy days!
