Advice required on exhaust
Posted: Wed Jul 07, 2010 10:43 pm
by Stealth_RS4
Bad news, was rear ended 2 weeks ago, not a major impact but cracked my bumper and damaged the exhausts. I was in sports mode at the time and afterwards I noticed the sports mode isn't working (no loud noise) and I'm down on power aswell. Going into the garage tomorrow for assessment all being paid for by the other parties insurance. Want to make sure everything is fixed properly, what items should I insist are completely replaced and not just fixed or patched up.What sort of diagnostics should be run by the garage to diagnose any problems.
Posted: Wed Jul 07, 2010 11:11 pm
by P_G
If there is no noise then your actuators (bits hat operate the flaps in the exhaust) sound like they are broke. They run off the same vacuum system as in your engine so if one section is broke the ECU's will turn the wick down hence why you feel down on power as well.
Best to have the complete back boxes including tips and actuators replaced.
Posted: Thu Jul 08, 2010 1:42 am
by ArthurPE
and check for vacuum leaks...make sure all the hoses etc are reconnected...
that is probably the reason for the lack of power
Posted: Thu Jul 08, 2010 11:11 am
by approved
full new system paid for by the perpertrator...accept nothing less.
Posted: Thu Jul 08, 2010 11:30 am
by Stealth_RS4
Thanks for advice lads. Jonathon, what should a full new system consist of ?
Posted: Thu Jul 08, 2010 1:42 pm
by Nib
jonathonturner wrote:full new system paid for by the perpertrator...accept nothing less.
And we wonder why our insurance premiums are going up...........
Posted: Thu Jul 08, 2010 2:31 pm
by Stealth_RS4
Reason why premiums are going up is because people aren't looking where they are going on the road and crashing into the back of people!! :D
Posted: Thu Jul 08, 2010 3:45 pm
by Terry1948
The exhaust system is all one so you would have no option but to fit a complete exhaust system from cats.
Posted: Thu Jul 08, 2010 4:35 pm
by P_G
You can get just back boxes and tips Terry. I have mine replaced under warranty because the exhaust valves were sqeeking badly and it wasn't a whole new system.
Posted: Thu Jul 08, 2010 6:43 pm
by Terry1948
P G did they cut the boxes off and then sleeve the new boxes or weld them back on will be handy to know and I am curious to know if you can buy just the boxes if it is not a warranty repair thanks
Posted: Thu Jul 08, 2010 6:57 pm
by P_G
Cut the boxes and welded. They come as a back box / actuator / tip complete assembly but I suspect you would be cheaper to find an exhaust fabricator and get them to weld the actuator tip assembly on to one of their back boxes and attach this to the exhaust pipes or get a cat back system.
Both would probably be roughtly the same if not cheaper than buying OEM back boxes.
