H&R Spacer part numbers
Posted: Sun Jun 27, 2010 8:28 pm
by mboy
Does anyone know the correct part numbers for H&R 10mm HC spacers to fit the rear on an B7 RS4, also do the 8mm HC spacers fit on the rear as they have a different chamfer size and bore depth?
Posted: Sun Jun 27, 2010 11:05 pm
by RS6chris!
AS FOLLOWS>>>
8mm......162555716
10mm.....202555712b
57.1mm center bore.
I,m running 8mm fronts and 10mm rears.
There wont be a problem running 8mm on the rears.
Got mine from the TT shop.
Posted: Mon Jun 28, 2010 8:39 am
by caldy
10mm.....202555712b
Hmmm not so sure about that code, unless they've changed the part number. Took me ages to track down at the time, ultimately speaking to the USA and Germany. The correct code was 202555713 for the 150mm hubface version. Suggest you check carefully before ordering as none of the websites are very clear.
Posted: Mon Jun 28, 2010 10:00 am
by MB2
If it helps I have just ordered a set of 2055571B also listed as 10mm ! I hope to be fitting them later this week so will let you know if they fit !
Posted: Mon Jun 28, 2010 1:20 pm
by mboy
Thanks all.
Posted: Tue Jun 29, 2010 11:20 am
by MB2
Well by spacers (2055571B) arrived today & as the car is on axle stands only tool a moment to offer them up and the fit looks perfect. They are a sung fit onto the hubs & putting them face to face the hub size looks perfect & the holes line up fine through to the hub.
I don't have any wheels at the moment so can't test for fit with a wheel but they certainly seem like the correct thing !
Posted: Tue Jun 29, 2010 3:38 pm
by Sims
MB2 wrote:Well by spacers (2055571B) arrived today & as the car is on axle stands only tool a moment to offer them up and the fit looks perfect. They are a sung fit onto the hubs & putting them face to face the hub size looks perfect & the holes line up fine through to the hub.
Is fitting 10mm spacers better than fitting 275 width tyres, instead of the 255.
Posted: Tue Jun 29, 2010 4:19 pm
by MB2
Spacers will push the wheels out so making for a more aggressive look, the wider section tyres are as I understand it more about getting some rim protection, which is why I will be fitting those when my existing tyres wear out. I guess they will also make the wheels look a bit wider as a side effect too. I have read on here 10mm + 275 fits OK so that is the set up I will end up with, can always get the spacers turned down a few mm if any problems anyway...
Posted: Tue Jun 29, 2010 4:38 pm
by Sims
MB2 wrote:Spacers will push the wheels out ...
Any impact on the suspension, camber, stress on hub?
Posted: Tue Jun 29, 2010 7:58 pm
by sonny
Sims wrote:MB2 wrote:Spacers will push the wheels out ...
It will promote negative camber, more you increase the axel width.
Which in turn could effect the thrust bearing.
Just make sure you have the car set up correctly (4WLA).
Posted: Wed Jun 30, 2010 11:43 am
by MB2
Really ? I did wonder about this but then thought Audi cheerfully changed the offset of the wheel from 8/45 on an S4 to 9/29 on an RS4 so effectively spaced the wheel out by 29mm - take your point on getting the allignment checked though do you think that is an urgent job or when next in job do you think ?
Am wondering if should take the spacers off now !
