Page 1 of 2
307.8bhp.....
Posted: Fri May 15, 2009 4:36 pm
by Oli
RE: 308.8bhp.....
Posted: Fri May 15, 2009 4:40 pm
by DavidRoss
your kidding? I thought Rs4's were 370hp? I'm completely lost now
Posted: Fri May 15, 2009 4:42 pm
by P_G
Is your graph any different to that you got at Paramount?
Posted: Fri May 15, 2009 4:49 pm
by Oli
P_G wrote:Is your graph any different to that you got at Paramount?
No not really, but quite clearly shows there still is a problem.. Sonny was there with his car, and that was nearly 80bhp more!! I guess I'll be keeping my appointment with Audi. CHarlie from SRR, suspected it was a gummed up inlet manifold, clogging the valve, and it feels just like the throttle isn't fully open.
I'll stick the plot up soon.
Andy, please can you pm your plot, so that I can show the dealer the differences
Posted: Fri May 15, 2009 5:52 pm
by Dom81
:shock: :shock: :shock:
Posted: Fri May 15, 2009 5:53 pm
by Blue_Thunder
You did better than Mike159 when he ran his old one at the AudiSRS day!
Think his was 302bhp.
Posted: Fri May 15, 2009 7:43 pm
by scaghead
oli, sorry to hear that..the thing about the janked up inlet does not make sence when you look at rob and jims results from the rr day?[only difference between the two rob had a de-coke ]but only a few horses between them..so we may be barking up the wrong tree, as this being the cause?? god knows........maybe we should try to sort out this head to head rs4 day on a airfield and compare the cars properly?
Posted: Fri May 15, 2009 7:53 pm
by Oli
Cheers SH. First of all Audi is having mine back to investigate - It certainly doesn't have the power increase/surge @ 5000+rpm, and when I finally get my scanner to work you can see my power/torque is low all the way through, when compared to Sonnys car
Posted: Fri May 15, 2009 8:00 pm
by Gazzer68
Sorry to hear Oli,
Yours is about the same age/mileage as mine?
same tyres, and mine only did 343hp, what were you pressures by the way?
Posted: Fri May 15, 2009 8:01 pm
by Oli
Factory standard pressure, almost irrelevant when my graph is so low - scanning as we speak
Posted: Fri May 15, 2009 8:38 pm
by Oli
As promised - sorry they are faint - Not sure how to darken them up??
Corrected flywheel graph
Wheel power - I think?
I believe this shows BHP as well as fuelling? Is this correct?
This is my plot against Sonnys, you can see my car is lacking right from the start
Comments Audi??
Posted: Fri May 15, 2009 9:25 pm
by Andyuk911
Have you removed and looked at the plugs ?
Posted: Fri May 15, 2009 9:28 pm
by Oli
No. They are brand new, put in with the major service, which has been carried out since the last dyno, 500 miles/1 month ago. The 10BHP increase is probably from the service and plugs only!
Posted: Fri May 15, 2009 9:31 pm
by Andyuk911
Per my pm .. this can be sorted .... you just need to be mega polite and go for a ride with the master tech ... they should be able to sort it out .. it just a logical process ...
Posted: Fri May 15, 2009 9:33 pm
by Oli
Hopefully that will all happen, starting next friday when I drop it off, and pick my diesel courtesy car up.......
