KW V3 Settings
Posted: Mon May 11, 2009 8:44 am
Hi Folks,
Finally ran into the dreaded DRC issue after 1 year of owning the car. Felt that the car wallowed strangely going into corners and true enough the front absorbers were both leaking upon checking by the dealership. Was quoted something like USD 2,650 to replace all 4 absorbers!!! Being a grey import, mine had no warranty.
KW just offered USD 2,450 for the full coilover replacement. Being way cheaper than the DRC repair, have decided to go down this route. 3 questions that I need help on from the more experienced fellas here:
1) What is the setting for the V3's that would get me almost similar ride balance as the original DRC? Or other optimal settings with balance of comfort and handling?
2) How big an impact would the addition of the H&R sway bars make to the ride? Would the ride suffer without it running KW?
3) For those that went with the H&R, did you change the whole front and rear or only rear?
Thanks in advance for the advice!
