Page 1 of 5
hesitation at high RPM
Posted: Mon Feb 09, 2009 9:23 pm
by almeister09
HELP,
I have an 06 plate RS4,@6,000 rpm there is splutter/hesitation for 2-4 seconds.Taken to dealer who cannot fault,no faults in any system,the ECU software version is the latest 090,ive been asked what octane i,m running on,which of course the dearest 98ron, anybody ANY ideas,this is an annoying problem.
I feel like i,m being fobbed off!!!!!!
RE: hesitation at high RPM
Posted: Mon Feb 09, 2009 9:44 pm
by pippyrips
2-4 seconds?! that's one hell of a splutter! Has the tech actually experienced the symptoms first hand? It could be a number of things but for starters look at the plugs...
Posted: Mon Feb 09, 2009 9:46 pm
by Marcus-RS4
plugs or coil packs failing? Anything coming up on VAG-COM?
Posted: Tue Feb 10, 2009 9:39 am
by W8PMC
Is the car fully warmed up??
The DIS displays to keep revs below 6000rpm until the engine is at normal operating temp & depending on driving style/roads it can take a good few miles before reaching the correct temp.
The car has a temporary limiter at 6K RPM until correct engine temp is achieved. I've been a little keen before now & hit that limiter as i'd assumed the engine was at the correct temp, but was obviously a little early.
Other than that i've never heard of such a stutter.
Posted: Tue Feb 10, 2009 10:09 am
by tartan_rob
Is this on part throttle or WOT?
Posted: Tue Feb 10, 2009 10:37 am
by almeister09
car is warmed up,can replicate at about 5,000 rpm more or less WOT,spark plugs have been replaced and coil packs are all good.Dealer says no faults in their 5052B diag equipment.
Does feel like a fuel restriction but i am no nearer.
Posted: Tue Feb 10, 2009 11:01 am
by david7m
Bad batch of fuel?
Dave
Posted: Tue Feb 10, 2009 11:09 am
by Marcus-RS4
W8PMC wrote:Is the car fully warmed up??
Is 6k cold limit due to your remap? Standard is 7k?
Posted: Tue Feb 10, 2009 11:47 am
by rAudiguy
even if you have the rev limmieted changed under a remap to 4.5k 5k 6k whatever your choice the display will still read 7k because this can't be changed.
I think just a typo from Paul re the 6k.
Jim
Posted: Tue Feb 10, 2009 1:12 pm
by W8PMC
My bad.
Did mean 7K, only limiter difference with the map is an extra 300ish RPM at the top end.
Read the O/P 6K then thought i've seen the number 6 (limiter vanishes at 60 degrees) so typed crap
Posted: Tue Feb 10, 2009 1:24 pm
by PetrolDave
W8PMC wrote:The DIS displays to keep revs below 6000rpm until the engine is at normal operating temp
It's 7000rpm (unless you've had it changed during a remap), and it's not advisory - the limiter is at 7000rpm until the oil temperature reaches 60 Celsius when it is moved to 8250rpm (unless you've had that changed during a remap).
Posted: Tue Feb 10, 2009 1:34 pm
by david7m
WOW, even 7k when coldish is a lot
Dave
Posted: Tue Feb 10, 2009 1:35 pm
by almeister09
Hot or cold this happens so i can rule out oil temperature, As stated i only use the high octane fuel,i have had this problem for some time..
Posted: Tue Feb 10, 2009 2:00 pm
by PetrolDave
almeister09 wrote:Hot or cold this happens so i can rule out oil temperature, As stated i only use the high octane fuel,i have had this problem for some time..
Coil packs have to be the number 1 suspect, but VAG-COM would usually show fault codes if it's them.
So maybe the plugs need changing? Do you do a lot of town driving and/or low revs?
Posted: Tue Feb 10, 2009 5:11 pm
by NGS521
Wouldn't the coil packs have forced the car into 'safe mode'?
