SR71 makes good points.
Agreed entirely on the French legal aspect and the ‘haven’t found it enforced yet’. I’ve certainly never carried and haven’t been Gendarm’d yet.
I’ve driven to Val D’Isere at least once a year for the last 6 years so the following is based on that experience.
Resort is important as is the time you arrive/leave.
Val is quite high for the Alps so I usually expect serious snow/ice on the mountain road there and usually that’s about what I find. Lower resorts will be considerably easier.
Timing: if you’re planning on arriving/leaving on ‘transfer day’ (usually Saturday in France I believe), then they usually clear and grit the roads all the way to the resort. Also the depending on exactly what time you do the last mountain climb bit, the road surface will be virtually clear due to the traffic on it. (12-4pm seems about peak). Admittedly you’ll also be doing about 3mph stuck between coaches
Equally, I guess if you’re not going to a major resort, or you need to drive some uncleared roads to cabins hidden way up the hills, then you’re dealing with a different ball game to me and the below probably won’t help.
I’ve taken both my C5 Allroad and my B5 RS4 to Val. Both obviously have Quattro but the difference in tyres was worlds apart.
Neither had issues getting traction and moving despite being dug out of snow at the end of the week and heavy snow downpours en route. However the Allroad’s Goodyear offroad/allroad tyres on the C5 had excellent braking, steering, feel etc. They were half worn tyres at the time. By comparison, the brand spanking new Pirelli Pzero Rosso’s were like trying to run on ice: you could get going without issue, but stopping, changing direction, or any sort of sudden action caused immediate ABS kick-in and virtually no control. It was a very very slow drive! Conclusion: summer tyres really do not work AT ALL on snow/ice/freezing temperatures.
I didn’t know about the Klack & Go Quattro – looks interesting if somewhat expensive at £200+ a pair.
Next time I’m out I’ve decided that I’m going to buy a full set of 4 proper snow/winter tyres. Fit them in the UK at the beginning and end on trip and store the rest of the year. I suspect there is very little in a ski resort that a Quattro can’t handle with a proper set of snow tyres. If you know you’re going to have your car for a couple of years, might well be worth a look at.
SR71 – I’d be interested to know how many times you actually had/decided to fit your chains/socks? Great thing about snow/winter tyres is they are always there. None of this ‘get out into the cold and spend 20 mins trying to fit them just to drive the 2 miles down the road before having to take them off again’.
Finally, just a friendly word on timing. No idea when you’re thinking of driving, but we’ve got things pretty nailed down now: Friday night drive to Dover, midnight ferry across the Channel. 6-7hrs bombing it on clear (to yourself) French toll roads, arrive bottom of mountain roads about 7am ish. Roads have just been cleared for transfer day. Spend 50 minutes driving up to resort (easily 3hrs if you try that at 2pm), arrive in resort, check-in, few hours sleep, lunch then off to the empty slopes which you have to yourself for the rest of the day as everyone else is still stuck on a coach queuing to get up the mountain!
It’s a bit hardcore, and we always run at least 2 drivers a car. But if you can do it, the easy travel and extra ski time are well worth it! ï
