Drivers Side Door Mirror
Posted: Tue Jan 06, 2009 9:01 pm
by RS4MAD
Hi All
Anyone know where I can get one of these from that won't break the bank! Some burk hit mine today and drove off - polite! :x
Anyone got any ideas how much I might be looking at?
Cheers Rich
RE: Drivers Side Door Mirror
Posted: Tue Jan 06, 2009 9:29 pm
by rAudiguy
if it's the glass your after try here. http://www.ecstuning.com/stage/edpd/pag ... ry=Mirrors
Posted: Tue Jan 06, 2009 9:56 pm
by RS4MAD
The glass is ok,it's the surround that's gone
Posted: Tue Jan 06, 2009 10:47 pm
by Oli
140 squid + VAT from Audi - Total rip off for a plastic cover, thats painted.
At least the mirrors on my 8P S3 were actually alloy
It just doesn't make sense alloy on a £26k car, and plastic 'alloy' lookalike on a £50k motor
Posted: Tue Jan 06, 2009 11:23 pm
by APM
have a look on the for sale site,theres a b7rs4 being broken for spares!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
Posted: Wed Jan 07, 2009 2:21 pm
by Jezzer
How easy are the mirror surrounds to take off? Would you need to take off from the inside of the door by removing some trim?
Posted: Wed Jan 07, 2009 7:58 pm
by Oli
They come off fairly easily - Pull the small triangular trim off the inside of the door - there are two screws underneath. Prise the mirroe glass off gently, which reveals two or three screws that hold the assembly onto the casing, remove these and the motor assembly, unplug theelectrics. This then reveals two screws that hold the retainer on - easy as that
Posted: Wed Jan 07, 2009 9:00 pm
by gmk666
Nick one off a chavved-up Corsa?
Posted: Thu Jan 08, 2009 8:45 pm
by RS4MAD
OliH wrote:They come off fairly easily - Pull the small triangular trim off the inside of the door - there are two screws underneath. Prise the mirroe glass off gently, which reveals two or three screws that hold the assembly onto the casing, remove these and the motor assembly, unplug theelectrics. This then reveals two screws that hold the retainer on - easy as that
Hi,
got a mirror from a salvage yard today £185 (bargain), does the inside triangular piece need to be pulled from a particular side and do I need a screw driver to prise it off ?
thanks Rich. :?
Posted: Thu Jan 08, 2009 9:38 pm
by Jezzer
Hi,
thanks Rich. :?
Isn't that more than a dealer would charge you then? earlier someone said £140 + vat - £161
Posted: Thu Jan 08, 2009 9:56 pm
by Virdee Autos
I think it's £140 for just the cover (backing), whereas he got a complete mirror for £185.....or at least I hope!
Posted: Thu Jan 08, 2009 10:53 pm
by Oli
Just use a very small screwdriver, or you might be able to lever it with your fingers
Posted: Thu Jan 08, 2009 10:59 pm
by RS4MAD
Jezzer wrote:
Hi,
thanks Rich. :?
Audi quoted £420+vat for the whole unit and then £92 an hour fitting!!!!!!!!!!!!!!! :shock:
Posted: Fri Jan 09, 2009 9:28 am
by Dom81
RS4MAD wrote:Audi quoted £420+vat for the whole unit and then £92 an hour fitting!!!!!!!!!!!!!!! :shock:
Sounds about right - replacing two nicked mirrors on my S4 was over £1200!
Thankfully it was a company car...
Posted: Mon Jan 12, 2009 11:50 pm
by DrNick
Exactley the same problem happened to me. Searched high and low to see if anyone sold the mirrors on the web but to no avail.
Was quoted £474 incl VAT fitted and colour coded by Audi.
Ended up paying £260 inclusive of VAT and fitting in the end as was able to use the original electrics/heater, so only needed shell and mirror.
Good luck
