Page 1 of 2
anyone else running 200 cell CAT ??
Posted: Sun Sep 28, 2008 9:28 am
by murgelloMatt
As title i am running 200 cell CAT, full resonated milltek and AMD map. The engine management light has now come on a total of 5 times and the code is saying that both CATs have failed. Have checked the CATs and they are fine so took it to AMD again and they are telling me it is the map. They have adjusted it twice but it still aint right. It also runs really bad on cold start up. I am waiting for the light to come on again!!
Has anyone else had any probs ????
RE: anyone else running 200 cell CAT ??
Posted: Sun Sep 28, 2008 9:30 am
by murgelloMatt
also i would like to add that i had no problem when the non res pipes were on the car ( had to lose them as the noise was to much and i do alot of miles
Posted: Sun Sep 28, 2008 9:57 am
by murgelloMatt
Another thing i have heard that a couple of tuners have had to take the cat of and put OE back on as they could not solve the problem ( kim collins )
Posted: Sun Sep 28, 2008 10:07 am
by P_G
One way to solve it is to have something akin to a Lambda sensor chamber. Lambda sensors normally slot into a place near the cats, when I have my S4 fitted with 200 cell cats and a s/s exhaust the custom fitter I used built a separate chamber for them as part of the system so they did not take readings directly from the gas flow through the cats as he had also heard of similar issues but providing an emmissions control system environement that would still allow them to perform a function.
I can't see how it is the map unless they have altered the fueling and ignition sequencing that causes the problem, but then it would have cused a problem from the start and not now.
I will also say at this point I don't know the exact ins and outs of how these things work however that was what I was advised.
Posted: Sun Sep 28, 2008 10:52 am
by Andyuk911
Interesting post, have you ever dynoed the car ?
Posted: Sun Sep 28, 2008 11:27 am
by murgelloMatt
yes mate an awful lot of dyno done
standard 387 horse
exhaust & map 408
if memory serves me right
Posted: Sun Sep 28, 2008 12:02 pm
by S2tuner
Cat diagnostics can be reprogrammed so the ECU allows 200 or 100 cell cats to work without any problems, but SOME tuners just don't know how to do it.
Posted: Sun Sep 28, 2008 6:05 pm
by murgelloMatt
so who can do it ????
AMD cant seem to sort it ????
Posted: Sun Sep 28, 2008 6:47 pm
by S2tuner
We can.
Posted: Sun Sep 28, 2008 7:18 pm
by murgelloMatt
based where ????
Oxford ?
Posted: Sun Sep 28, 2008 7:25 pm
by murgelloMatt
ok just seen link ??
will give you a call if AMD do me a refund and stop messing around!!
gotta wait for the light to return, normally only 2 or 3 tanks of fuel
Posted: Sun Sep 28, 2008 7:39 pm
by RED_ROCKET
Go to MRC they know what there doing.
Posted: Sun Sep 28, 2008 8:02 pm
by P_G
murgelloMatt wrote:based where ????
Oxford ?
Matt,
If you need someone close to Oxford try Weltmeister / WRC Technologies otherwise as said MRC.
Posted: Sun Sep 28, 2008 8:06 pm
by S2tuner
Matt, we are based in Banbury
200 Cell Cats
Posted: Mon Sep 29, 2008 7:55 am
by caldy
Had my custom exhaust, including 200 cel cats, fitted by AAS Exhausts in Newcastle. Drove to Holland for re-map by JDE and no problems whatsoever some 1500 miles on. Both AAS and JDE are very good at what they do.
