b7 service light reset
Posted: Mon Sep 15, 2008 11:19 pm
by wabtheking
can this be done with the vag tool?
or will this not work with a can bus?????
is there a way to reset it thought the dash?
cheers
will
minor service by the way,
RE: b7 service light reset
Posted: Tue Sep 16, 2008 7:41 am
by BlingBling
The service light on S4's can be reset on the dash. So imagine the same is possible with a RS4. It will reset the service intervals to Fixed Term. I.e. 12 months. Check the manual for instructions.
Posted: Tue Sep 16, 2008 4:49 pm
by Dom81
It's not in the manual
You'll need VAG-COM to switch between Long Life & Annual, but if you're after a reset -
Ignition off
Hold in the spanner button on dashboard
Turn key to ignition on (not start) while still holding the button
Finally press and hold the trip reset (0.0) button and the service interval should clear in about 5 secs
Posted: Tue Sep 16, 2008 5:36 pm
by PetrolDave
For fixed intervals you can do it from the dash, but for AVS you have to use VAG-COM or get the dealer to do it with their VAS.
Posted: Wed Sep 17, 2008 1:21 pm
by wabtheking
cheers guys, done now, miles and days goes to ../../../ but told this can take 3days or bout 300 miles to sort itself out
thanks again
will
