Anyone had coil pack failure (yet)?
Posted: Wed Aug 20, 2008 8:41 pm
by rjkflyer
Got the engine warning lamp on today and a quick check with Ross-Tech VCOS shows ECU number 2 reporting a random/multiple misfire and a specific misfire detected on cyl 4. Car running fine however.
Dealer confirms that it sounds like a coil pack - obv in process of failing or intermittent.
Wondered of experience of others? Only done 17k...
RE: Anyone had coil pack failure (yet)?
Posted: Thu Aug 21, 2008 10:30 am
by Ozrs4
You're lucky to get 17K! Mine failed even before I took delivery. The dealer rang when I was on my way to pick it up and said EPC light came on and diagnosed with coil pack failure. They changed all 8 before I took delivery.
Posted: Thu Aug 21, 2008 10:48 am
by PetrolDave
I've done nearly 27K miles with no sign of coil pack failure.
Posted: Thu Aug 21, 2008 1:26 pm
by P_G
My car has done 3k miles and no CP failure.
Posted: Thu Aug 21, 2008 9:05 pm
by rjkflyer
Talking to the Mobile tech (a good and new idea for my dealer - man comes to your car at home and fixes it where possible) doesn't seem to be a big issue with RS4. Seem to have been some revisions to coil packs so the later ones are pretty reliable.
To be fair, the VDCS indicated a once-off intermittent fault so replacement was precautionary but done under warranty.
Posted: Thu Aug 21, 2008 9:17 pm
by P_G
P_G wrote:My car has done 33k miles and no CP failure.
Posted: Fri Aug 22, 2008 2:51 am
by 8zero8
i've had 3 replaced, but you should check, there is an open recall for early 07's, fuel pressure sensor, my car was cutting out like a bad cp, same symptom, and having had 3 replaced, i assumed it'd be my fourth, but it was the fuel pressure sensor...ck your VIN at your shop for open campaigns...
Posted: Fri Aug 22, 2008 7:12 am
by rjkflyer
That's interesting - i was aware that mine needed the low pressure fuel sensor recall (the tech confirmed that - it's an early '06) but didn't know it could be a possible cause of poor running which i guess might have tripped the ECU.
Posted: Sun Aug 31, 2008 9:05 am
by tartan_rob
I had 1 fail and Audi changed all 8.
Posted: Thu Oct 30, 2008 4:16 pm
by rjkflyer
Hmmm, car in dealer for DRC repair (again) and they advised they had changed a coil pack as ECU indicated a Cylinder 4 misfire. EXACTLY same error as i started this thread with.
Bit odd to have same failure twice (although no actual misfire evident). Anyone else seen this? Must suggest something else perhaps? ANy ideas?
(Have posted details on VAG-COM forum)
Posted: Thu Oct 30, 2008 6:21 pm
by ghoonk
do you guys get EPC or any visible indicator with coil pack failure?
Posted: Thu Oct 30, 2008 8:48 pm
by rjkflyer
Yes, the little amber engine lamp comes on in the instrument cluster.
Posted: Thu Oct 30, 2008 10:39 pm
by ghoonk
Fair enough. So far, so good *knocks on wood*
