Page 1 of 2
Could It Be DRC Again??
Posted: Mon Feb 25, 2008 5:39 pm
by W8PMC
I'm hoping to hell it's not, but had some very odd spirited moments over the weekend (had not driven the car in anger since she's been serviced & had front shocks replaced).
Without boring you with every detail, a sharp left i've taken many times at the same speed, this time had my rear end scrabbling for grip & 4 wheel drifting around it (quite out of shape). Next taking a fairly gentle right hander at speed, the car started again drifting & pretty much lost traction.
The roads were bone dry & my tyres are the correct psi & plenty of tread.
TBH the back end just never felt as tight as it used to (if that makes sense), as their always appeared too much drive to the rear :shock:
Nothing has changed on the car other than a full service & of course the front shocks replaced along with the relevant cylinders. The dealer & Audi refused to change the opposing shocks, stating it is not a requirement on the RS4.
Anyone got any ideas??
Can't get into a dealers for a couple of weeks as i'm mucho busy, but could do with some pointers as she felt far from grippy the 1st time i've pushed her since leaving the workshop.
Posted: Mon Feb 25, 2008 6:12 pm
by ARSEY4
Could it be the alignment? if they dont realign then they tend to mark and put back.
Posted: Mon Feb 25, 2008 6:28 pm
by W8PMC
Forgot to say all 4 wheels were fully re-furbed (nice job) & yes the dealer did get the tracking & alignment checked, i however doubt as they only charged me £30ish that it was the top drawer alignment check. I had no issue with traction before the front shocks were replaced, just knocking on re-bound & when investiagted the dealer found both front shocks were leaking.
Posted: Mon Feb 25, 2008 6:31 pm
by Love_iTT
W8PMC wrote:...they only charged me £30ish that it was the top drawer alignment check....
You don't get a full 4 wheel alignment for £30 Paul. well if you do then let me the address. I've seen prices as low as £60 but never £30.
Graham
Re: Could It Be DRC Again??
Posted: Mon Feb 25, 2008 6:41 pm
by ChrisRS4
W8PMC wrote:Without boring you with every detail, a sharp left i've taken many times at the same speed, this time had my rear end scrabbling for grip & 4 wheel drifting around it (quite out of shape). Next taking a fairly gentle right hander at speed, the car started again drifting & pretty much lost traction.
Sounds like it handles the same as an M3 :D
Posted: Tue Feb 26, 2008 9:37 am
by ARSEY4
W8PMC wrote:Forgot to say all 4 wheels were fully re-furbed (nice job) & yes the dealer did get the tracking & alignment checked, i however doubt as they only charged me £30ish that it was the top drawer alignment check. I had no issue with traction before the front shocks were replaced, just knocking on re-bound & when investiagted the dealer found both front shocks were leaking.
Insist that the 4 wheel alignment is done properly, if you remove suspension components I doubt very much whether they go back in the exact same place even when marking. A full alignment done by a proper set up will cost 100+, Ive sat with a perfectionist who did mine and he took a good 2.5 hours.
Posted: Tue Feb 26, 2008 8:32 pm
by W8PMC
To clarify, i did not have a 4 wheel alignment done during the warranty work etc. I thought i'd requested one on my list (if required), but i was defo not charged for one, just a regular balance after the wheel re-furb & that of course was not £30.
The car is going in on Friday to be checked & have a full 4 wheel alignment done (thanks for the call Rob), so i'll report back then.
Posted: Fri Feb 29, 2008 4:28 pm
by W8PMC
Well the full 4 wheel alignment was done today (thanks Rob) & the nearside rear toe-in was out very slightly, although this was unlikely to be enough to cause the lack of rear wheel traction. Some of the other values were out a touch but were within guidelines.
All values correct now & i'll see how she performs over the next few days.
Posted: Thu Mar 06, 2008 8:40 am
by hairyaardvark
Keep us posted mate - I'm seeing exactly the same symptoms on my '06 car (only done 15K miles and the current tires are decent) ...... cheers
Posted: Fri Mar 21, 2008 10:53 am
by m5killer
mine does the same and ive only had it for three days now, brand new tyres etc
Posted: Fri Mar 21, 2008 4:18 pm
by W8PMC
No problems, the car is performing perfectly.
Posted: Fri Mar 21, 2008 5:15 pm
by s4woody
nice name m5killer..mite put that to the test next time im in london..lets just hope the crew will let you change it to m5killed me... :biggrin3:
Posted: Fri Mar 21, 2008 7:52 pm
by m5killer
s4woody wrote:nice name m5killer..mite put that to the test next time im in london..lets just hope the crew will let you change it to m5killed me... :biggrin3:
that wont happen the name m5 killer is because of my alpina B10 BI-turbo 560 bhp and 850nm so m5 m6 current ones can only see my dust :D and my middle finger salute, the salute is just the icing on the cake as they see my dust
Posted: Fri Mar 21, 2008 11:27 pm
by s4woody
alpina B10 BI-turbo
nice.. :thumbs:
Posted: Sat Mar 22, 2008 11:52 am
by m5killer
s4woody wrote:
alpina B10 BI-turbo
nice.. :thumbs:
cheers woody, what part of surrey you in as ive got a bungalow in surrey
