Two issues with my RS4.
Posted: Mon Dec 31, 2007 6:22 pm
by djcevo
First of all - the suspension started doing this before and it seems to have come back and to be honest I can't remember exactly what Audi did to repair it. When I go over a bump when the shock drops back down it knocks, no knocking on the way up, it's only on the way down. Any ideas???
Problem two: discs have just started to feel they they are warped, slight judder when braking gently, I have done no heaving braking at all!!! Again, any ideas?!?!?
RE: Two issues with my RS4.
Posted: Tue Jan 01, 2008 12:36 am
by simple1
Discs do tend to go through cycles, mine felt as if they were warped after very heavy break into a roundabout, put them through a heat cycle, lots of hard breaking to build up heat then gently drive home and let them cool. Not heard of the knocking before, sounds like a top mount type of noise.
Posted: Wed Jan 02, 2008 10:46 am
by tartan_rob
I have the same suspension woes but ECERY quattro I have had has been them same. Audi know its a weak point.
Posted: Wed Jan 02, 2008 1:42 pm
by Bolt
Suspension knocking - no idea, sorry.
But on the discs issue, it could be warped discs as you say, if they have got really hot over and over again. But also, if he car has been standing in the damp conditions for a while, maybe, just maybe , the pads have rusted to the discs. When you 1st drive away, the disc surface where the pads had been is rusty, and needs a few miles to scrub it back to normal.
I've had this on my race bike which has low steal discs, and hence rust easily. If it is this, then the judder may clear itself afte a few heavy breaking manouvres.... otherwise if warped, and its going to cost !
Posted: Fri Jan 04, 2008 5:13 pm
by dougbmwm3
Hi there, new to Audi's after years of M3s. I've just collected a 10month old RS4 Avant. Front suspension creaks and groans and i have the knocking going over bumps. Is this really to be normal?? Also if the engines revved and allowed to return to idle, there a gentle squeek / groan from the back of the car. Sounds like something to do with the exhaust????
Posted: Sun Jan 06, 2008 12:55 am
by hbk
Took car in today for a health check and the front right shock had a slight leak and they are replacing both under warranty...
The car is not being used this week so they are arranging for collection from my home and return.
I must say, the dealer so far has been brilliant and happy to mention them, 'Watford Audi'.
Posted: Sun Jan 06, 2008 1:12 am
by alex_123_fra
hbk wrote:Took car in today for a health check and the front right shock had a slight leak and they are replacing both under warranty...
Nice to hear, I'm quite close to them so am considering taking the car to them for next service.
Posted: Tue Jan 08, 2008 5:36 pm
by crafty1
I have the same issue on my RS4 avant, with the suspension knocking over a bump on the way down, was thinking of getting it checked but havent got round to it yet, would be interested to hear what your outcome is. thanks
Posted: Tue Jan 08, 2008 7:02 pm
by t_urbo
dougbmwm3 wrote:Hi there, new to Audi's after years of M3s. I've just collected a 10month old RS4 Avant. Front suspension creaks and groans and i have the knocking going over bumps. Is this really to be normal?? Also if the engines revved and allowed to return to idle, there a gentle squeek / groan from the back of the car. Sounds like something to do with the exhaust????
Could be the exhaust flaps opening as it returns to idle. Mine do the same.
Posted: Tue Jan 08, 2008 7:07 pm
by djcevo
crafty1 wrote:I have the same issue on my RS4 avant, with the suspension knocking over a bump on the way down, was thinking of getting it checked but havent got round to it yet, would be interested to hear what your outcome is. thanks
Will let you know when I eventually get round to booking it in!
Discs warped
Posted: Wed Jan 09, 2008 7:45 am
by Skip
Ye seems to happen, mine started to judder at 10k miles. Audi Dundee checked them and agreed they were warped replaced discs and pads on warrenty.
Not overly impressed with the quality of mine I bought second hand in Aug 07 with 7.6K on the clock. Has had 3 warrenty claims to date, front alloys peeling, discs, and driver seat air bladder leaking. Going in today as headlight washer seems to have given up the ghost.
PS had a test drive in Perth Audi's black R8 on Monday hate the manual gear box interior seams of lower quality than my RS4. Gonna get a test drive in the Rtronic one when it goes on the road in March.
