No Cabin Heat from Heater Vents
Posted: Mon Mar 13, 2023 11:10 am
Hi all,
After years of trouble free motoring, my B7 RS4 has developed an irritating problem.
With the car up to temp and a demand for hot air in the cabin, there is no heat from the interior vents. Its cold, really cold (but I guess the ambient outside has been quite cold recently).
I've tried all sorts of settings (Auto, Hi, Demist etc. etc.) but nothing seems to make the cabin air vents blow hot air.
Car runs fine. Gets to temp and stays at the right temp without issue.
Coolant level is bang on.
My (inexpensive) OBDII reader is not throwing any codes.
I am going to pull back the top hose on the heater matrix feed from the engine bay to expose the air bleed to see if that sorts the issue, but both the inlet and outlet to the heater matrix (from the engine bay) feel hot, so I am assuming this is flowing as it should.
Whilst I wait for the hose clip remover to arrive (these clamps look to have not moved since new) can anyone suggest any other checks to see what may be causing the issue. I am hoping to tackle this job in a day, before having to resort to taking it to a garage
Thanks all, for reference Avant '07 B7 RS4 UKRHD.
