Sporadic EPC lamp
Posted: Thu Sep 16, 2021 11:42 am
Hello Community
I have been the proud owner of an Audi RS4 B7 Avant in Daytona Gray for half a year.
Brief information about the car: It will soon hit 215,000km and the clutch has recently been renewed, carbon clean was done 15,000km ago and the oil consumption is within reasonable limits. It has a software by MTM according to the previous owner. (Because of the newton meter lock)
I'm so far at peace with the car, but a problem that keeps coming back plagues me, I hope you can help me.
The EPC light arrives sporadically while driving, mostly when it is warm and I drive it over 3000 rev's. The car feels healthy and still has full power, except that it limits the engine speed to around 6600. The car will sit overnight and the next morning the light is still on, but then it goes out again after 5 minutes of driving.
The EPC lamp can trigger if:
~ I use the full rev range with a warm motor (Never been done cold before for obvious reasons)
~ When cruising at around 3500 rev's
~ I can drive days without it ever lighting up, so it's very sporadic and difficult to narrow down to what exactly it is
I read out the error and it says "P2015 intake manifold switching actuator position sensor / switch"
I also had the car checked through from the workshop I trust, they took a close look at the intake manifold and said the actuators were not broken and still work perfectly.
They exchanged 2 transducer sensors since they didn't work anymore, an oil drain pipe in the intake tract was also broken, they replaced this.
Unfortunately, the EPC lamp still comes on from time to time and is still the same error P2015.
Perhaps someone in this forum was/is struggling with the same error as me and can give me some advice.
Kind regards,
a desperate RS4 driver
Kind regards,
