HVAC dramas
Posted: Wed Jun 09, 2021 6:39 am
I have had this issue the past 2 summers, and it's time to finally figure it out and get the issue resolved.
On long road trips with the A/C running on "Cool" or close to it (16.0 to 18.5 degrees C), the system works well for about 45mins. Duct temps with a independent temperature probe show about 2 degrees C at the dash vent above the cup holder. But then the whole system starts to blow warmer and warmer air, minute by minute. If left alone, the vent temps reach 30 degrees C. If I select "ECON" mode, the duct temp takes a few minutes to start to drop, and then after 10 mins it's back down to about 10 degrees C, so I switch ECON off and the system drops the duct temp back towards 2 degrees C again, but this time it only takes about 15mins until it starts warming up again. I have to repeat this process over and over and over.
Outside temp's are about 25 degrees C to 35 degrees C, and this ONLY happens when it's warm/humid outside. In winter the car will chug out 2 degree air all day for hours on end. My VAG Scanner doesn't show any faults, so I'm stumped as to where to start.
My initial thoughts were that the Evaporator may be freezing over? Or I have a dodgy sensor somewhere in the system. I've had the system checked at an air conditioning workshop, but he couldn't fault it.
Has anyone experienced this/got any tips to try work it out?
THANKS LEGENDS!!
THANKS LEGENDS!!
