Non starter
Posted: Fri Apr 16, 2021 9:54 pm
by Adymars
Evening all. I have a B7 cab with 90k on. Its got a new Bosch battery, it's trickle charged throughout the week and I can heat the relays working. I used it a week last Friday and since then it's not started. It won't turn over. Could it be the starter motor ?? Im gonna get RAC to diagnose it I think.
Sent from my SM-N976B using Tapatalk
Re: Non starter
Posted: Sat Apr 17, 2021 9:43 pm
by Silverfox42
Clutch switch fault could be the reason, if the sensor is stuck 'open' the start stop button won't work.
You could try removing/unplugging one or both. Worst that will happen (I think) is that you will lose cruise control and the car will start without the clutch being pressed down.
Re: Non starter
Posted: Mon Apr 19, 2021 10:57 pm
by enclavet
Changed 4 starter related relays, 2 batteries before I determined it was my starter. Have similar miles and started out as intermittent starting issued to eventual not starting. Pulled codes mentioned low voltage across the relays which make sense if your starter is bad. Good test is to check voltage drop when starting. If it's a new battery and the voltage drops while you crank the key, time for a new starter or maybe ground cable.
Starters are not too expensive, if you can DIY the job wasn't so bad also.
Sent from my Pixel 5 using Tapatalk
Re: Non starter
Posted: Wed Apr 21, 2021 8:41 am
by Adymars
Thanks both.
Re: Non starter
Posted: Wed Apr 21, 2021 7:33 pm
by dhali
A nice chap on ( illya? Apologies if I've spelt it wrong) here did a
YouTube video on how to change a starter motor on a B7 RS4 .
