B7 RS4 slipping out of 2nd on overrun
Posted: Wed Nov 11, 2020 11:02 am
by willcoles
A B7 RS4 that I'm considering buying slipped/popped out of 2nd gear on overrun on the test drive. I worked the gearbox and managed to get it to do it again but I wouldn't say it happens all of the time.
Is this a common fault? What is likely to need replacing? Is the repair something that should be done asap or could it wait till spring?
Thanks in advance.
Re: B7 RS4 slipping out of 2nd on overrun
Posted: Wed Nov 11, 2020 2:02 pm
by rs user
if its only on the overrun you can work around it till it needs a clutch and do it then,if it popped out under load it would be more of a worry
my particular style of driving would probably never uncover / encounter that issue as for the most part i just go up and down the gears,i dont trickle through traffic much-which is where i can imagine that fault would manifest itself as a bit of a pita
it wont do any harm driving it like that providing gearbox fluid is clean
Posted: Sun Jan 24, 2021 10:29 pm
by Covkiller
That doesn't sound like a clutch related problem but a synchro one to me. I'd speak with a gearbox specialist, they'll tell you straight away or speak with MRC.
