Wanting to change clutch fluid
Posted: Sat Jul 18, 2020 10:24 am
Hi,
When hot my B7 has difficulty engaging gears when stationary with engine running. If i pump the clutch it improves so i'm thinking a fluid change could help.
But .......
How the f... do you get to the slave bleeder ?
Had it up on my ramp yesterday but can't even see the bleeder.
Do i need to disconnect exhaust from gearbox and then drop grearbox sub frame ? Does this allow access ?
The manual just says remove the drive shaft heat shield and everything is rosey.
Appreciate your help and wealth of knowledge. Surely this shouldn't be to difficult, should it ?
Gary
But .......
Gary
