Hi All,
I've been advised this is most likely a controller problem rather than the bulb. I phoned Audi and gave them my reg number and they said the part I needed was 8P0907391. Before I go and buy a new one (ouch) I thought I'd better check:
1) is the controller the most likely cause ? It's only happening on left side. If I turn the light off and on again the problem goes away. Intermittent fault in other words
2) how do I check this is the right part ? Apparently it's for the non-adaptive xenon headlights. How do I know which type I've got ?
3) was going to fit it myself, but will be an evening job by the roadside in the dark. Is this feasible ?
Many Thanks !
Ian
Flickering Left Bulb on B7 RS4
Ian
B7 RS4 Avant
1984 911 Carrera (hotrod)
B7 RS4 Avant
Re: Flickering Left Bulb on B7 RS4
If the lights go up/down and then in and out during the self test at startup then you have adaptive lights. If they just go up and down then you have non-adaptive.
Could be a bulb on its way out, my one did this years ago and changing the bulbs fixed the problem. You are supposed to change Xenon bulbs every 3 years anyway as the light output drops off over time.
I left it to a garage to install, you need to move bits of the air intake to access the drivers side as well as having small hands!
Misano Red RS4 B7 Avant
Thanks - Anyone recommend a bulb supplier ?
Ian
B7 RS4 Avant
B7 RS4 Avant
I will be fitting Osram Nightbreakers shortly based on positive feedback from here.
Users browsing this forum: No registered users and 90 guests
