ENGINE LIGHT
Posted: Mon Nov 18, 2019 10:46 pm
by JAMES RS4
Hello everyone, I am new to the forum, 2 months ago I bought an RS4 b7 and I am very happy with it ( i come from a GOLF R 7) But yesterday, while driving quietly and calmly, suddenly the engine light appeared in the panel. I was scared, but I was doing performance tests and the car works perfectly, there is no loss of performance, the revs are stable, the sound is the same as always, everything exactly the same as always, but the light still there...
IS not the EPC light, is the engine light.
Any ideas what to do now? COnsidering the car works perfecly...i have to worry about that?
Re: ENGINE LIGHT
Posted: Mon Nov 18, 2019 11:12 pm
by marc1
Emissions check engine light. Likely one (or more) of the lambda sensors. You need to get a
VCDS scab for fault codes to identify which.
Re: ENGINE LIGHT
Posted: Mon Nov 18, 2019 11:18 pm
by JAMES RS4
OKay, to 2 weeks ago i remove the center resonator (put instead a straight pipe) can this be reason of the lambda error?
I think about it, but.. the lambdas are before the center section right?
ENGINE LIGHT
Posted: Tue Nov 19, 2019 12:27 am
by AA_954
JAMES RS4 wrote:OKay, to 2 weeks ago i remove the center resonator (put instead a straight pipe) can this be reason of the lambda error?
That should not bring out a CEL, you need to invest in a cheap obd scanner or get obd11 so you can share with us the codes that brought the CEL. It could be a range of things and given that its a CEL with no EPC the most common ones are misfires however, we need the codes to help you in diagnosing the issue (s) and suggested next steps
Sent from my iPhone using Tapatalk Pro
Re: ENGINE LIGHT
Posted: Tue Nov 19, 2019 1:41 pm
by JAMES RS4
AA_954 wrote: ↑Tue Nov 19, 2019 12:27 am
Okay a lot of thanks, this weekend i´ll go with a friend he have a OBDELEVEN scanner
i will post the codes!
Re: ENGINE LIGHT
Posted: Wed Nov 20, 2019 10:43 am
by JAMES RS4
Today I was crusing alone (with my engine warning light on
) and suddenly, again, another warning light comes on, EPC this time. So, now I go with the two lights on, engine and EPC. The car works perfectly.
Is it a serious doctor?
Re: ENGINE LIGHT
Posted: Wed Nov 20, 2019 11:02 pm
by JAMES RS4
Re: ENGINE LIGHT
Posted: Thu Nov 21, 2019 2:36 am
by AA_954
When the EPC light is on this will limit your revs to 7k. Did you turn the car off and on again and still get an EPC? Usually it goes off and comes back on after a few cycles of codes repeating. Code reader will point you in the right direction
Re: ENGINE LIGHT
Posted: Thu Nov 21, 2019 10:11 am
by JAMES RS4
AA_954 wrote: ↑Thu Nov 21, 2019 2:36 am
thanks. saturday will post the codes!
Re: ENGINE LIGHT
Posted: Thu Nov 21, 2019 5:08 pm
by JAMES RS4
One question, I can use the car? o can be dangereous ? I need to go to some places....
Re: ENGINE LIGHT
Posted: Sat Nov 23, 2019 4:45 pm
by JAMES RS4
OKay, these are the code errors that have come out in
Vagcom. We have deleted the errors and have not gone out again in the dash, and the car works perfectly.
The question is, can they come out again?
System description: 4.2L V8 / 4V FSI ª
Software Number: 8E1910560
Software version: 0080
Hardware Number: 8E1907560
Serial number: XXXXXXXXXXXXXX
Extended coding: 01040003180F0160
Error Codes:
P0491 - Secondary air system, bank 1 Flow too low Lower limit value not reached
static
Priority: 0
Frequency counter: 6
Driving cycle: 255
Mileage: 111236 km
P2015 - Transmitter pos. intake manifold flap / ctrl. air flow non-plausible signal non-plausible signal
Sporadic
Priority: 0
Frequency counter: 1
Driving cycle: 255
Mileage: 112325 km
