Page 1 of 6
SEAT Exeo RNSE Sat Nav in B7 RS4...
Posted: Thu Aug 08, 2019 9:27 am
by fairzy
I recently bought a SEAT Exeo Sat Nav to upgrade my RS4’s old gen 1 RNSE.
Firstly, so far it’s a nice simple swap - DIS is fully working, screen is amazing in comparison with the old version.
One small problem, BOSE isn’t working - the front speakers seem ok but the rears are very quiet (almost like only the door tweeters are working) and the Sub is definitely not working. I’ve read online about people swapping pin 7 / 3 but it looks like that’s for people swapping from Concert to RNSE, not old to new RNSE.
Any suggestions? Could it be a coding issue?
Thanks in advance!
Re: SEAT RNSE Sat Nav in B7 RS4...
Posted: Thu Aug 08, 2019 1:05 pm
by Rick_RS4
I'd say coding
Posted: Thu Aug 08, 2019 1:12 pm
by fairzy
Rick_RS4 wrote:I'd say coding
Thanks mate, any ideas what to check or just plug the old one in and compare with settings for the new?
Posted: Thu Aug 08, 2019 2:31 pm
by fairzy
After a bit more researching online I might have found the problem... Need to check
VCDS tonight when I can plug it in but need to make sure BOSE is configured:
56 (Radio System)> Function 07 > should be xxx9xxx
Should also be able to change the start screen:
18 (start screen) > Adaption > Start Screen > 0 = standard or 3 = RS 4
I’ll try this and report back - hopefully it will help someone out.
Posted: Thu Aug 08, 2019 3:11 pm
by Kenny147
The Ross Tech wiki page you want to look at, seems to be down at the moment but that’s the first place to start.
One thing before you start changing the coding, run a scan and save the txt file. It’ll show the current coding of each module and you might need it if things go awry.
Apologies if I’m telling you something, you already know.
Posted: Thu Aug 08, 2019 3:33 pm
by Jon_J
You will need to enable Bose otherwise the Bose amp is powered correctly.
Second point you can’t select RS4 for the screen. Well you can but it doesn’t do anything. This is because the later generation RNSE was not available in the RS4 so there is no splash screen loaded. You can however set it to Audi.
Posted: Thu Aug 08, 2019 3:48 pm
by fairzy
Kenny147 wrote:The Ross Tech wiki page you want to look at, seems to be down at the moment but that’s the first place to start.
That was my first thought and the first place I went to - usually it’s really helpful. Hopefully it’ll be back online soon.
Posted: Thu Aug 08, 2019 3:49 pm
by fairzy
Jon_J wrote:You will need to enable Bose otherwise the Bose amp is powered correctly.
Thanks - should I just do 0 then - from memory the other settings were S3 / TT etc?
Posted: Thu Aug 08, 2019 3:51 pm
by Jon_J
fairzy wrote:Jon_J wrote:You will need to enable Bose otherwise the Bose amp is powered correctly.
VCDS gives you the code translations. Can’t remember what Audi is.
Posted: Thu Aug 08, 2019 9:44 pm
by fairzy
Quick update - everything is now working as it should. I connected
VCDS and it was already coded ok (9 as above for BOSE) but just needed an MMI reboot (hold radio and setup until it restarts). I only changed the startup screen in
VCDS. If it helps anyone you stay in the radio section (57) and click on adaptations rather than coding, change the channel to 18 and then the setting from 6 (if from a SEAT) to 0. It now shows the Audi MMI startup screen.
After all of that I’d definitely recommend swapping to a SEAT Exeo navigation unit. It cost me less than £200 and was plug and play - in fact after resetting the unit I only needed
VCDS to change the startup screen.
Posted: Thu Aug 08, 2019 11:30 pm
by JamesBaby
Hi. Can you comment on the performance of the sat nav please. What is the latest nav year for it? Where can you get one and do you have a part number please.
Thank you
Posted: Thu Aug 08, 2019 11:31 pm
by murph7355
fairzy wrote: ↑Thu Aug 08, 2019 9:44 pm
Was that £200 for the whole RNSE unit?
What other features does it give?
Presumably 7 digit postcodes? Can it take bigger memory cards? Anything else interesting?
Posted: Thu Aug 08, 2019 11:58 pm
by Kenny147
The MkII RNSE unit has a higher res screen, faster processor and takes higher capacity SD cards. The best part for those that want an OEM look is that you can connect an A3 AMI unit.
Posted: Fri Aug 09, 2019 7:57 am
by Jon_J
7 digit postcode is not available on them. Some discs have it, if I recall 2015 had it but otherwise no. It’s not related to the unit, it’s related to the disk. I have 2018 disc in mine at the moment.
The MMI is the best feature for me, also I have a high res reverse camera.
For me, I’m yet to see an aftermarket unit that looks like it belongs. The MK2 RNSE of course looks like it belongs and with the addition of the MMI means you can connect your phone to it and browse your music from the RNSE. Sound quality of the RNSE & MMI compared with blue tooth or headphone jack is night and day.
Posted: Sun Aug 11, 2019 6:39 am
by fairzy
Jon_J wrote:7 digit postcode is not available on them. Some discs have it, if I recall 2015 had it but otherwise no. It’s not related to the unit, it’s related to the disk. I have 2018 disc in mine at the moment.
Reversing camera you say
Easy to do? What parts do you need?
