4 pot rear brake conversion
Posted: Tue Jun 04, 2019 12:06 pm
by Rick_RS4
I've just fitted the R8/Lamborghini 4 pot rear brakes and spot caliper to my B7 , I know theres a few people on here with the BBK on the rear and wondered what the pedal feel was like.
On mine biting and stopping is awesome but the pedal travel until bite is a little more than i thought it would be .
Maybe i haven't bled them correctly or possibly need a larger mastercylinder. I've not read of any complaints so wondered if it was a problem my end .
Re: 4 pot rear brake conversion
Posted: Tue Jun 04, 2019 8:16 pm
by MikeFish
Looks cool Rick. I haven't done the conversion so can't really answer but when the brakes on my C7 were changed they pedal became spongier even though the garage re-bled them. After a few weeks they went back to normal. I assume it was a bit of air trapped somewhere and eventually just worked it's way out.
Posted: Tue Jun 04, 2019 9:21 pm
by Rick_RS4
Thanks Mike, re painting the fronts now, full strip down and re finish. Ah I've read they get air trapped and you should take the caliper off and twist it round to try to work any air loose.
Once the fronts are on I'll re bleed the whole system again and see what happens .
Posted: Sun Jun 09, 2019 8:49 am
by MattboyR32
Where did u source the brakes and conversion kit if you don’t mind me asking?
Posted: Sun Jun 16, 2019 1:02 am
by Rick_RS4
I've been looking on Ebay mainly for the calipers etc, the pads and disks are new
Posted: Sun Jun 16, 2019 5:59 am
by AA_954
MattboyR32 wrote:Where did u source the brakes and conversion kit if you don’t mind me asking?
If you’re looking for a decent kit that is already put together for the B7 I would check voshmods.com , thats where I bought mine.
Sent from my iPhone using Tapatalk Pro
Posted: Wed Jul 31, 2019 9:27 pm
by Rick_RS4
Sorted this I needed to bleed the abs with
VCDS all good now brakes are awesome now
Posted: Thu Aug 01, 2019 4:30 pm
by George
Did you get the longer pedal travel sorted? it is normal because the area of the 4 pistons is much more than the area of the single piston caliper. If it is a problem you may need to change the master cylinder.
Posted: Thu Aug 01, 2019 8:59 pm
by Rick_RS4
George wrote: ↑Thu Aug 01, 2019 4:30 pm
Yes I did thanks. Just bled the abs and it's like like oem feel
Posted: Fri Aug 02, 2019 8:21 am
by George
Yes, indeed! One more thing - on the 4 pot calipers you have two bleeder nipples on each caliper, not one, you have to bleed both of them!!!
Start from the internal one and after this you do the external.
