Page 1 of 2
Wheel spacers
Posted: Thu Dec 27, 2018 10:11 am
by MrRSB7
Hi
I’ve added spacers to my standard wheels, with the standard tyres....
The car is lowered on bilstein suspension from what I can tell.... a bit too low in my opinion...... now I’ve added the spacers the tyres rub in the arches....
Can i raise the ride height of the suspension?? Is this an easy/inexpensive task?? the wheels look really good I don’t want to lose the spacers.
Many thanks
Re: Wheel spacers
Posted: Thu Dec 27, 2018 10:40 am
by andyg72
Fronts a doddle
Rears are a bit more awkward expect skin loss :)
I assume you fitted 10mm spacers ?
If so drop to 8mm problem solved
Re: Wheel spacers
Posted: Thu Dec 27, 2018 10:55 am
by MrRSB7
20 mm all round
Re: Wheel spacers
Posted: Thu Dec 27, 2018 10:58 am
by andyg72
MrRSB7 wrote:20 mm all round
I’m surprised you can move the car with 20mm
I doubt anyone uses that size
8mm is the desired size
Re: Wheel spacers
Posted: Thu Dec 27, 2018 11:34 am
by MrRSB7
That’s what they recommended in the garage where they powder coated the wheels 😂😂😂
Re: Wheel spacers
Posted: Thu Dec 27, 2018 12:24 pm
by MikeFish
Either they meant 20mm per axle ie 10mm per side or they have no idea.
Re: Wheel spacers
Posted: Thu Dec 27, 2018 12:30 pm
by Fatneck73
I got 8mm allround plus PSS9’s (altho dunno how much lowered buy). Tis ‘mostly’ ok until Mrs, nephews and Pooch also get in 😂😂😜
Re: Wheel spacers
Posted: Thu Dec 27, 2018 3:25 pm
by Fatneck73
Although, sits pretty nice (when not loaded up).
Re: Wheel spacers
Posted: Thu Dec 27, 2018 11:49 pm
by pule333
Fatneck73 wrote:I got 8mm allround plus PSS9’s (altho dunno how much lowered buy). Tis ‘mostly’ ok until Mrs, nephews and Pooch also get in ImageImageImage
You bought another one!!!! Always knew you would ImageImage looks really really good!!!
Re: Wheel spacers
Posted: Fri Dec 28, 2018 8:39 am
by Fatneck73
Yeah..wasn’t planning on it but couldn’t resist. 😂😂😂. Showing above so Op can see that Bils PSS9’s and 8mm’s work ok albeit not sure what drop I’ve got.
Re: Wheel spacers
Posted: Fri Dec 28, 2018 2:09 pm
by MrRSB7
Re: Wheel spacers
Posted: Fri Dec 28, 2018 2:14 pm
by pule333
This don’t look looks 20mm spacers to be honest. Perhaps it’s 20mm per axle? Where did you buy the spacers?
Re: Wheel spacers
Posted: Fri Dec 28, 2018 2:24 pm
by MrRSB7
Yes maybe your right...... the garage did supply and fit, he mentioned 20mm .... I assumed it was 20 each
Looking at the spacer , it’s no way near 20 mm 🤦🏻‍♂️
Re: Wheel spacers
Posted: Fri Dec 28, 2018 3:27 pm
by Covkiller
Why not just remove your spacers, less hassle.
Personally I don't get spacers unless you really need them due to aftermarket wheels.
Re: Wheel spacers
by Covkiller
Burn me :FIREdevil:
