Page 1 of 3
How low is too low???
Posted: Mon Nov 12, 2018 11:27 pm
by Jon_J
Re: How low is too low???
Posted: Tue Nov 13, 2018 12:47 am
by MikeFish
Ouch. This was a constant fear of mine with my 40mm springs on the 6.
Posted: Tue Nov 13, 2018 7:51 am
by Jon_J
MikeFish wrote:Ouch. This was a constant fear of mine with my 40mm springs on the 6.
Having them rolled back in on Sunday. Hopefully they go back ok.
Posted: Tue Nov 13, 2018 7:54 am
by FrazerD
Here’s hoping it rolls back okay. Are you coilovers or springs?
Posted: Tue Nov 13, 2018 7:55 am
by Jon_J
FrazerD wrote:Here’s hoping it rolls back okay. Are you coilovers or springs?
B16 coilovers.
I wouldn’t mind but it had two new front wings about 3 month ago!
Posted: Tue Nov 13, 2018 9:41 am
by FrazerD
Jon_J wrote: ↑Tue Nov 13, 2018 7:55 am
B16 coilovers.
That’s not so handy. I’m assume you are just going to raise it up a bit.
Posted: Tue Nov 13, 2018 11:27 am
by Robnic
Ouch, think they'll be ok at that height though after you have them rolled back, typical after the new wings eh! Let us know how it goes.
Posted: Tue Nov 13, 2018 12:08 pm
by Jon_J
FrazerD wrote:Jon_J wrote: ↑Tue Nov 13, 2018 7:55 am
B16 coilovers.
No I’m hoping once rolling the arches I won’t need to
Posted: Tue Nov 13, 2018 12:36 pm
by Jon_J
Robnic wrote:Ouch, think they'll be ok at that height though after you have them rolled back, typical after the new wings eh! Let us know how it goes.
Agreed
Posted: Thu Nov 15, 2018 7:16 pm
by Shockerboy
The optimum for this car is 20 to 25 mm , this keeps it practical , reasonably comfrotable and avoids issues like this . the fitting of a coil over kit offers 35 to 50 mm its simply too much even though many think it looks good . There is always a limit to the safe lowering of a car with out upsetting the practicality. this unfortunate issue is probably due to excessive drops even though it appears that the wheels and tyres are standard so it isnt aggrivated by bigger ones. Not familar with B 16 but most Coil overs have shorter body than a standard shock . the length of the shock body is the limiter for wheel movement and stops the wheel hitting the body work , if the shock body is shorter that will cause this problem .
Posted: Thu Nov 15, 2018 7:33 pm
by rwilsonrs4
i,m going to be probabaly repled nastly but anyhow , did you get your geometry set ???all folk want their cars stanced so thats an issue, do you know your castor .camber and steering geometry when the car is lowered too much , its not like the geometry on a race car as its all adjustable whereas a road car is not , if you lower the suspension on front you have increased camber which wears the inside of the tyres and also you have toe out which wears the inside of tyres rear lower you have camber too , so get your alignment checked and get adjustable top arms to set the camber , but then it rubs the wings as the top of the tyre will be further out , so with my b16 its about 10mm lower but still all in spec , just ! adjusted the toe by 1 mm , but sounds like nothing ,but if you drive fast you are loading up the suspension bushes so you get toe out thus why you gt steering wander and tyre wear , rant over
Posted: Thu Nov 15, 2018 11:02 pm
by mustdash
Thanks for putting "rant over" at the end of your post. As I started reading it, I was thinking to myself "in the absence of any apparent full stops, how on earth will I know when this diatribe is at an end?". Luckily, you put something in there other than a full stop or an exclamation mark, so we all knew that you'd finished.
Sorry Jon - can't offer any useful advice.
Posted: Fri Nov 16, 2018 5:17 am
by TrevoRS4
This same thing happened to mine with the same coilovers set a little higher than yours. I’m also on OE wheels and no spacers. Hopefully rolling it back works for you. Mine started to make some pucker markers on the fender from the pressure put on the bent part. May need to bring it to a PDR guy now.
Posted: Fri Nov 16, 2018 12:42 pm
by Jon_J
TrevoRS4 wrote:This same thing happened to mine with the same coilovers set a little higher than yours. I’m also on OE wheels and no spacers. Hopefully rolling it back works for you. Mine started to make some pucker markers on the fender from the pressure put on the bent part. May need to bring it to a PDR guy now.
That’s my thoughts, get them rolled, if need be I’ll get PDR. All else fails I’ll buy a new wing.
Posted: Fri Nov 16, 2018 12:44 pm
by Jon_J
More than happy to listen to rants. The geometry has been set. They back is correct as it is adjustable, the front in set but the camber is wrong as you have explained. Doesn’t affect the handling as you rightly pointed out it isn’t a race car so no issue if it slightly out.
As for tyre wear, so be it. If I have to put tyres on it 30% earlier than every one else does then that’s the price I’ll pay.
