Help needed, Engine Light On - Lambda Heating Errors
Posted: Sun Feb 18, 2018 5:14 pm
Hi all
For the last few days my EML light has come on. I reset it, thinking it may have been a random occurrence. Anyway the fault is back. Done a scan on VCDS and its showing fault on the lambda on both banks:
The faults suggest the problem maybe located in an area common to all the sensors, but I have no idea where to start looking
Any ideas where to start ?
Thanks for any help
Prit
Code: Select all
Address 01: Engine Labels:. 079-910-560-BNS1.lbl
Part No SW: 8E1 910 560 HW: 8E1 907 560
Component: 4.2L V8/4V FSI ª0080
Revision: --H15--- Serial number: XXXXXXXXXXXXXX
Coding: 010C0003180F0160
Shop #: WSC 66565 257 00032
VCID: 63CF804CA21F315C65-8036
2 Faults Found:
000049 - Oxygen (Lambda) Sensor B1 S1: Heating Circuit
P0031 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Status: 11100010
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 172363 km
Time Indication: 0
Freeze Frame:
RPM: 1915 /min
Load: 29.0 %
Speed: 50.0 km/h
Temperature: 35.0°C
Temperature: 12.0°C
Absolute Pres.: 1000.0 mbar
Voltage: 13.970 V
000055 - Oxygen (Lambda) Sensor B1 S2: Heating Circuit
P0037 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 172363 km
Time Indication: 0
Freeze Frame:
RPM: 2166 /min
Load: 36.1 %
Speed: 57.0 km/h
Temperature: 36.0°C
Temperature: 11.0°C
Voltage: 13.970 V
Readiness: 0010 1100
Address 11: Engine II Labels:. 079-910-560-BNS2.lbl
2 Faults Found:
000081 - Oxygen (Lambda) Sensor B2 S1: Heating Circuit
P0051 - 002 - Short to Ground - MIL ON
Freeze Frame:
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 172363 km
Time Indication: 0
Freeze Frame:
RPM: 1919 /min
Load: 29.0 %
Speed: 50.0 km/h
Temperature: 35.0°C
Temperature: 12.0°C
Voltage: 13.970 V
000086 - Oxygen (Lambda) Sensor B2 S2: Heating Circuit
P0056 - 004 - Malfunction / Open Circuit - MIL ON
Freeze Frame:
Fault Status: 11100100
Fault Priority: 0
Fault Frequency: 1
Reset counter: 255
Mileage: 172363 km
Time Indication: 0
Freeze Frame:
RPM: 2164 /min
Load: 36.5 %
Speed: 57.0 km/h
Temperature: 36.0°C
Temperature: 11.0°C
Voltage: 13.843 V`
Thanks for any help
Prit
