Hi Neil
Thank you for your email. We no longer sell Viper due to the lack of support we had from them plus the design been 10 years old with no signs of updates or release of a new design. Pandora is not only a better quality product but offers more features and layers of security.
Please see packages and prices below.
Pandora Security upgrade packages
Security packages what's included as standard
All our Packages include our exclusive SecureMyCar extras, designed by us which protects you against...
OBD port Key cloning Roll jam Key scanning
OBD port immobiliser - Designed to kill the signal from your On board diagnostics port when the alarm system is armed. This will help protect your car from key cloning theft.
Secondary digital Immobiliser - The second layer of security included is our NEW Push button Start engine immobiliser. The immobiliser will kill your vehicles ignition circuit protecting against Key scanning and proximity key theft.
Remote encryption
All system utilizes 858 MHz long range multichannel automatically switching radio path and AES-128 algorithm dialog encryption with remote recognition to ensure protection from hackers and code grabbers.
Fully fitted
All systems prices include fully fitted However if you require for us to come to your home or work address, there will be a mobile fitting charge between £65-75
PACKAGES - SUMMARY
BRONZE - Designed for the customer who wants an LCD remote which will keep in contact with their car unto a mile range.
SILVER - Designed for the customer who would like an OLED long range remote and maximum Protection including internal motion, proximity warn away and impact protection
GOLD - Designed for the customer who would like to be connected to their car anywhere in the world through their smartphone but doesn’t want to carry an extra LCD remote on their keys. (Subscription required and GPS Tracking is an optional extra)
PLATINUM - The Ultimate includes LCD remote, Smartphone Control, Tracking and location, hidden immobilisers, duel Proximity sensor, internal motion, impact and tilt sensors as well as anti highjack. (Subscription is required)
Packages
BRONZE PACKAGE
Get instant notifications displayed on your long range LCD remote within a miles range. Screen also displays information of the vehicles bonnet, boot, doors and additional sensors. If one of the zones or sensors are activated by a thief, the remote will beep and flash to warn the user. Other useful information including fuel level, engine/cabin temperature as well as the vehicle battery voltage which are also displayed on the LCD screen (This is vehicle dependant)
-Long Range LCD Remote
-OBD port Immobiliser
-Impact/Shock Sensor
-Movement sensor
-120db Siren
Cost £575.00
SILVER PACKAGE
Get instant notifications displayed on your long range OLED remote within a miles range. Screen also displays information of the vehicles bonnet, boot, doors and additional sensors. If one of the zones or sensors are activated by a thief, the remote will beep and flash to warn the user. With the Silver package, you will also have a dual proximity sensor which will not only sound on the car but will also alert you on your remote. Other useful information including fuel level, engine/cabin temperature as well as the vehicle battery voltage which are also displayed on the LCD screen (This is vehicle dependant)
-Long Range OLED Remote
-Movement sensor
-Dual Proximity with warn away
-120db Siren
Cost £680.00
GOLD PACKAGE
Security upgrade package designed for the user who doesn't want to carry round a second LCD pager key fob on his or her car keys. The system can be securely controlled from your original key fob and instant notifications come through Pandora's Smartphone app, straight to the owners smartphone. If the alarm is activated or one of the sensors triggered, the alarm will instantly notify you through your phone. You can also arm and disarm the system through the app. If you are an android or iOS user, everything can be adjusted via the smartphone app. You can turn on and off sensors or adjust the sensitivity from inside the app it self. So when a Shock sensor is too high, you simply slide the slider to adjust sensitivity, or simply switch it off.
As with all of Pandora's alarm systems. This package also features algorithm dialog encryption with remote recognition to ensure protection from hackers and code grabbers proven to be un-crackable. The tiny little alarm immobiliser fob which sits on your car keys works at a programmed distance from your car, normally set to 5-10meters away (depending on vehicle). When the fob is in this zone the original key will or disarm the Pandora. If the fob is outside the zone and not detected by the Pandora alarm it will ignore all commands to disarm keeping the system, OBD port immobiliser and engine immobiliser fully armed. GPS tracking is also available on this package. Please note subscription is required for this package.
Bluetooth Immobiliser Tags Smartphone App Control OBD Port Immobiliser 2ns Engine Immobiliser Impact/Shock Sensor Movement Sensor 120db Siren 6 months subscription
Cost £850.00
PLATINUM PACKAGE
The most advanced security package in the world! This package is our flagship package designed for the owner who wants maximum security and all the features we can offer. This package includes control from both immobiliser keys, top of the range OLED display long range remote and full smartphone control, tracking with adjustable Geofence. Emergency panic button with microphone in car, which will automatically call up to 5 phone numbers of your choice in an emergency. Proximity keyless arm.
If you are an android or iOS user, everything can be adjusted via the smartphone app. You can turn on and off sensors or adjust the sensitivity from inside the app it self. So when a sensor is too high for its environment, you simply slide the slider to adjust sensitivity, or simply switch it off.
Change notifications set up, monitor, control and track your car real time. And much, much more.
This package has everything needed to keep your car where you left it.
This Package also includes an anti Hijack system with immobiliser key cards. This means that if you are ever in a situation were you could be forced to leave your vehicle or you are dragged out of the vehicle and immobiliser card leaves the vehicle, at a set speed your vehicle will stop and the alarm will activate. Proximity keyless lock and arm. Alarm will arm when the keyfob leaves a set distance from the vehicle. Subscription is required for this package.
Sensors
Extra sensors included in this package.
Dual proximity sensor with warn away. Proven to be the most advanced proximity sensor on the market today with less false alarms.
Tilt sensor, to notify you if your car is jacked up or lifted.
Impact sensor, with warn away for light impact.
Motion sensor. Works like an accelerometer on your phone.
All sensor activations including warn away will be notified through your smart phone through the Smart plus app.
This package has everything needed to keep your car where you left it and extra luxuries like handsfree locking and unlocking, for extra convenience.
OLED Long Range Remote Tracking, Smart phone app Bluetooth Immobiliser tags OBD Port Immobiliser 2nd Engine Immobiliser Impact/Shock Sensor Tilt Sensor Proximity Sensor with Warn away Anti HiJack 120db Siren 6 Months subscription
Cost £1350.00
Or £1250.00 without remote (control through phone)
ADDITIONAL EXTRA TO ANY PACKAGE -
REMOTE START
Fords - £150
BMW - £225
Range rovers - £250
Mercedes (Special order only) £1000
Other models £POA
Other Extras
Mobile fitting to come to your home/work address- from £65
Tilt sensor - £65 (included in platinum)
Glass break sensor - £45
AntiHijack - £150 (included in Platinum)
Thinkware DashCam front and rear £350.00
Global telemetrics tracker £400 (annual subscription required)
Things to know:
All package prices include VAT
All prices are final and are subject to change
The prices do not include mobile fitting for an installer to come to your home or work address.
We require a safe area for the installer to work on your vehicle where he can open all doors safely.
If you opt to have your system fitted at a car dealers, We will need cover and a direct contact number the sales person you have been dealing with.
All our installers are fully trained with our pandora specialists and are to install the systems correctly and professionally.
If you know what package you would like please book here using our booking form
www.securemybooking.co.uk
one of team will contact you to confirm a date.
Times cannot be given due to the nature of the job but the installer will call you when he is 30 minutes prior to arrival time.
We do require a deposit to secure your booking. You can pay this by BACs or card payment over the phone. (Credit cards have a 2.5% surcharge)
For bookings, sales or any questions please contact us on:
Tel: 01172440019
Email:
sales@SecureMyCar.co.uk
www.SecureMyCar.co.uk
Many thanks
Sarah
Secure My Car Ltd
Office 01172440019
Web
Email
Sales@SecureMyCar.co.uk
Secure My Car Ltd, is a limited company registered in England & Wales,
Company No 8538872
VAT No 200 3533 73
