Headlight re-alignment after lowering?
Posted: Thu Nov 09, 2017 11:53 pm
by max_b
Is this something that is required?
I've got a slight flickering of the headlights within the first few minutes of use then they settle down to normal without issue.
Only started after suspension replacement/lowered ride height
Re: Headlight re-alignment after lowering?
Posted: Thu Nov 09, 2017 11:55 pm
by Jon_J
My understanding is they are self levelling.
Posted: Fri Nov 10, 2017 9:15 am
by FaisalJ
Perhaps just a bulb on its way out?
I've only ever had one xenon bulb fail on me - flickering first, then it started lighting up purple at startup.
Posted: Fri Nov 10, 2017 11:32 am
by Davidol
Flicking is normally bulbs on its way out as Faisal has said. Normally a good idea to replace them both as typically if one is going the other won't be far behind and it's a bumper off job to change the bulb. Osram can be had for around £100 a pair
Posted: Fri Nov 10, 2017 9:38 pm
by lushman
I had exactly the same issue and a new set of bulbs as mentioned cured the issue for me.
Posted: Sat Nov 11, 2017 10:00 am
by Grandadg90
It can be done without the bumper being taken off and headlights in situ. Just requires a bit of patience.
Posted: Thu Nov 16, 2017 4:15 pm
by Covkiller
And small hands
Posted: Thu Nov 16, 2017 4:42 pm
by Jon_J
Like Beadle!!!
Take the bumper off, it’s not that hard
