Page 1 of 2
Annoying clicking noise from front wheels
Posted: Thu Jun 01, 2017 7:05 pm
by DavidRS4
As per above. Annoying clicking noise from front wheel area. Did it on old brakes and now just had new brakes all round and it still does it.
Although the nuts, bolts and metal slider bits weren't changed. Going to do that next.
Any other ideas or anyone experienced this?
Need this resolved as it's quite loud and irritating :bash:
Re: Annoying clicking noise from front wheels
Posted: Thu Jun 01, 2017 8:08 pm
by RS4B8LYF
DavidRS4 wrote:As per above. Annoying clicking noise from front wheel area. Did it on old brakes and now just had new brakes all round and it still does it.
Mines gone in today as this has just started on front passenger when turning, they said it needs grease?
Posted: Thu Jun 01, 2017 8:12 pm
by TommyC
Wheel spacers?? Might need a clean on the spacer to hub interface area as even a little dirt came make them uneven.
Posted: Thu Jun 01, 2017 8:31 pm
by jonytek
Mine started also after a few laps on the ring. Only hear it at low speed. Thought it might be cv joints?
Posted: Thu Jun 01, 2017 8:46 pm
by marc1
Wheel bearings?
Posted: Thu Jun 01, 2017 9:04 pm
by Dantheman84
Does it do it whilst turning or in a straight line of it makes the noise when turning then I would cv joint have you jacked up car and turned wheel does it make the noise then?
Posted: Thu Jun 01, 2017 9:58 pm
by RS4B8LYF
Dantheman84 wrote:Does it do it whilst turning or in a straight line of it makes the noise when turning then I would cv joint have you jacked up car and turned wheel does it make the noise then?
I did state "when turning"
Posted: Fri Jun 02, 2017 6:04 am
by DavidRS4
It does it all the time. When I start out it hardly does it. Then after a mile it's doing it constantly.
Posted: Fri Jun 02, 2017 8:45 am
by RS04YOB
I had it with mine it was the wheels rubbing with the spacers just needed to tighten them up
Posted: Fri Jun 02, 2017 11:38 am
by Shoppinit
Wheel bolts too long?
Posted: Fri Jun 02, 2017 2:56 pm
by RS4B8LYF
Regarding mine, it's stock set up so can't be the above
Posted: Fri Jun 02, 2017 3:59 pm
by jonytek
Mine happens when driving straight, slightly worse when turning left and disappears when turning right. Are CV joints a known issue? I haven't heard of it on these cars before.
Posted: Sat Jun 03, 2017 9:01 am
by transitman
That is typical of a CV Joint (Outer)
Posted: Sat Jun 03, 2017 10:03 am
by jonytek
It is. Anyone know what sort of cost this is to have repaired? I assume people tend to do both at the same time.
Posted: Sat Jun 03, 2017 12:52 pm
by transitman
Only need to do the side that clicks...
