Revs not quite right
Posted: Sun Mar 19, 2017 1:21 pm
by vroomrs4
Hi all
When I put my foot down on the excelerater The revs go up as normal but then when I take my foot off the revs hangs there for couple seconds which doesn’t feel right, has anybody else had this problem,
Someone said it could be the clutch switch.
Advice much appreciated.
Re: Revs not quite right
Posted: Sun Mar 19, 2017 1:22 pm
by dizziebug
We have the same problem - changed the switched no change changed the MAF sensor its fixed other things but not that
Posted: Sun Mar 19, 2017 1:23 pm
by dizziebug
Switches sorry
Posted: Sun Mar 19, 2017 2:25 pm
by nij
It might be the PCV valve as it will have perished over the years, it's mounted under the carbon fibre RS engine cover.
Posted: Sun Mar 19, 2017 4:10 pm
by dizziebug
Good suggestion
Posted: Sun Mar 19, 2017 4:22 pm
by vroomrs4
Great, i'll have a look at that.. Thank you
Posted: Tue Mar 21, 2017 9:56 pm
by Dantheman84
Yes best way to test pvc is remove you oil filler cap with engine
Running if it bogs done and almost cuts out your valve if definitely faulty hope this helps
Posted: Wed Mar 22, 2017 9:19 pm
by vroomrs4
Thanks for that tip..
Posted: Wed Mar 22, 2017 9:28 pm
by Dantheman84
vroomrs4 wrote: ↑Wed Mar 22, 2017 9:19 pm
No worries I know this cuz mines has failed last week so in the process of stripping down and carrying out carbon clean too
Also I have ordered spaces for inlet manifold that's ment to
Make a difference too so we will see
Posted: Sat Jan 06, 2018 8:38 pm
by Stigaream
Did you find out what was wrong ?
Posted: Sun Jan 07, 2018 1:05 am
by rs user
Dantheman84 wrote: ↑Tue Mar 21, 2017 9:56 pm
are you sure? read elsewhere on here that the rs4 b7 still does that with a new valve fitted? ....
Posted: Sun Jan 07, 2018 7:17 am
by Seattle-squash
Based on my experience, yes it still bogs down some but far quicker recovery and although mine did not shut down engine when it failed/was replaced, it almost stalled. So before and after was still noticeable different, upon change.
