Smoke on startup
Posted: Sun Dec 18, 2016 12:28 am
by O3mrt
I have spent hours of searching and still no definitive answer. Every cold start I get heaps of white smoke which is so rich in smell it can seriously burn your eyes.
The smell and smoke disappear within a minute. The car is garaged every night and sometimes not started until 2pm. So I believe that it cannot be condensation.
My old s3 had the same issue until I removed the SAI.
Has anyone had the same problem, removed the SAI and the problem disappeared?
Thanks,
Marty
Re: Smoke on startup
Posted: Sun Dec 18, 2016 12:35 am
by pule333
Mine does the same. And I have removed SAI.
Posted: Sun Dec 18, 2016 6:21 am
by O3mrt
pule333 wrote:Mine does the same. And I have removed SAI.
so removing the SAI and blocking the holes made no difference to the smoke issue?
Did it change anything at all?
Posted: Sun Dec 18, 2016 9:42 am
by Silverfox42
My B7 used to do this. I took it into Audi twice to investigate Plugs, the oil manifold and any fuel issues - nothing conclusive.
Speaking with other owners this behaviour is not unusual and something to do what the start up 'over run' which is designed to heat the Cats up quickly. Levels and colour of smoke vary by car and conditions.
I just lived with it and it seemed to get no worse over 4 years of ownership.
Posted: Sun Dec 18, 2016 10:47 am
by jaysrs4
Try this - if you've been out in it (and it's obviously fully up to temperature). On the way home, like any good RS4 owner, give it a good bootfull a couple of times. I'm not saying drive it like you stole it, but a good couple trips up the rev counter. I've found it doesn't do it at all after this. If you trundle around in it and park it up, you'll find it'll do it. Not to mention, this'll contribute to carbon build up.
Posted: Sun Dec 18, 2016 11:09 am
by pule333
To be honest with you, because I have no main cats, I figured this was the reason for smoking from cold anyways. Removing SAI did make it warm up slower. Sometimes I can drive for good 10min before oil up to 61deg...
Posted: Sun Dec 18, 2016 11:38 am
by O3mrt
jaysrs4 wrote:Try this - if you've been out in it (and it's obviously fully up to temperature). On the way home, like any good RS4 owner, give it a good bootfull a couple of times. I'm not saying drive it like you stole it, but a good couple trips up the rev counter. I've found it doesn't do it at all after this. If you trundle around in it and park it up, you'll find it'll do it. Not to mention, this'll contribute to carbon build up.
I can definitely confirm that I don't get up when close to home, I'm still in the turbo frame of mind, drive off boost when close to turning the engine off.
I will give it a crack and report back.
Posted: Sun Dec 18, 2016 1:38 pm
by pule333
Ha ha my wife said to me last week: "how do I know that you gonna be home in next 5 min? Are you Revving your car on purposefully?" Lol my reply was, "just doing some maintenance love" ha ha
Posted: Thu Dec 22, 2016 1:02 am
by Covkiller
Mine used to do this, but I have no cats. MRC sorted it out on my last service. I'll look on my receipt and post the fix tomorrow.
Posted: Thu Dec 22, 2016 9:55 am
by Jules
Sorry but I'm so glad to read all this as mine does it also and I was starting to worry lol.
I also have no cats but I don't remember my last rs4 doing it.
I will try what Jay said also
Posted: Thu Dec 22, 2016 11:39 am
by MikeFish
It's a known issue for cars with no pre cats. Mine started doing it the day I had my pre cats removed. I also had the SAI removed on the same day.
Posted: Thu Dec 22, 2016 10:10 pm
by Covkiller
MRC changed my Oil Separator and it stopped smoking. There always a little bit on start up, but no where near as before.
Posted: Thu Dec 22, 2016 11:47 pm
by matt-jones
Mine does it too but not massively, called MRC who said it's perfectly normal on a cold start, if it does it on hot starts then that's an issue.
Posted: Sat Dec 24, 2016 1:02 am
by O3mrt
Can 100% confirm that this works. Thank you sooooo much.
Posted: Sat Dec 24, 2016 9:50 am
by jaysrs4
Good stuff. It's a big old engine, it needs exercise ;)
