I went for a vehicle inspection today and the off side rear spring is cracked. I was also told there was a problem with one of the engine mounts.
Any advice ? How much should it usually cost to sort it ?
how much should it cost ?
Re: how much should it cost ?
Engine mounts are about £250 just for the part. Probably an hour or 2 to fit.
Any recommendations where to get it done ? Don't want my pants pulled down over the price
i would do both back springs-and dependant on which side mount throw a starter in too if its starter side...failed starters pretty common it would seem
Was there an error code on the engine mount only, or are you experiencing any issues 'hands on'?
I was talking to the guys at stertman a while back (experts with the RS models) and they told me almost all B7 RS4 do have an engine mount fault code but it does not really bring any issues.
Audi RS4 Avant
[2014]: blacked out wheels & grill: center res delete : flaps open
[2015]: brembo & yellowstuff : michelin pss : h&r spacers
[2016]: sachs performance clutch : decoked : led there be light : black window trim
[2017]: stertman stage 1 : black headlights & clear corner mod : gruppe m air intake : gutted resonators
Yes it's a common fault and one that can easily be ignored but mine made it vibrate a bit more at caertain revs (high idle).harding wrote:Was there an error code on the engine mount only, or are you experiencing any issues 'hands on'?
- 2nd Gear
I agree; do engine mounts and consider upgrading (ECS or O34 if you ask me), also starter when you are there since they are cheap.
