Hi all,
I've just brought a Daytona Grey Avant B7 RS4, late 2006, 128,000 miles, two owner with loads of history.
It needs some work: DRC seems to be really noisy and clunky and it seems to wallow a bit.
Clonks mainly come when suspension seems to drop into bumps.
Bills show that about 20,000 ago it had two new front shocks and a DRC valve, so should I persevere with DRC or go coilovers?
Thought that it was lower rear control arm as the bush was shot but now suspect its way more involved.
Also the EPC light has come on, the first time i really revved it, (when thoroughly warm), so suspect flaps, decoke or related issues.
I've had 3 S4s, all Avants, a yellow 2.7 Biturbo, a Sprint blue V8 and then a sprint blue V6, with a Mugello blue RS6 in the middle, but this is my first RS4.
Spent plenty of time lurking to glean as much as I can: it's all fascinating!
Sold a BMW 130i M Sport LE and that was a really taught car: RS 4 seems all a bit loose so obviously needs work.
Does anyone know a good indy in the Bournemouth area ?
Simon.
Independant Dorset, DRC.
Re: Independant Dorset, DRC.
Trust me, I was in the same boat. Thinking should I keep or go coilovers.
The ugly truth is, DRC will fail again and again and again. Not at the component you fix but somewhere else. Unless you replace everything! And I mean everything! All the lines, all the struts, all the valves.. it will still fail again .
I went with Bilstien B14. And could not be happier! Trust me, you won't regret it.
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
Hi Pule, I am considering Bilstein B14 myself as I can't see that I would be adjusting the damping as on the PSS9 s.
Thanks for the recommendation.
That was my line of though exactly as far as I know, b16 have 9 settings. Anything 5-9 is pure crap. Toooo soft. Setting 4 is best all rounder. And this is what b14 are set at as well. As much as I like to think "because race car" it's not, it's my daily and comfort is quite important day to day.pennpromo wrote:Hi Pule, I am considering Bilstein B14 myself as I can't see that I would be adjusting the damping as on the PSS9 s.
Enjoy!
RS4 B7 aka Vinnie
RS4 B7 aka Vinnie
