Wear sensors ( ceramic pads )
andyg72
Re: Wear sensors ( ceramic pads )
Post by andyg72 » Tue Sep 20, 2016 7:36 pm
irn_bru_ce wrote:Any chance of measuring the material thickness of those new pads , and the thickness of the old pads when the wear sensor came on
Technically the light hasn't come on tho it did for one day so I'm not sure it's been triggered due to wear
Pads new have 10 mm
I would say I'm down to 4mm
irn_bru_ce
Post by irn_bru_ce » Wed Sep 21, 2016 1:22 am
OK cool , I'll give mines a measure, they must be close to new
I've had the warning come up a half dozen times over the last 18 months, so must be debris or something
Current - 07 Avus Silver B7 RS4 Avant : Ceramics, Non Valved Non Res Milltek, K&N filter, SS+, adaptive xenons, black optics, KW3, 034 rear ARB, rear drop links & front adjustable top arms.
Past - 00 Saxo VTS : 266mm Mi16 calipers, Quaife ATB, 20mm torsions bars, 24mm ARB, Vibratechnics mounts
87 Vauxhall Belmont: 1.6L, 15" rockford fosgate subwoofer in 3 cuft sealed box, 5ch Rockford fosate amp, JBL components
Oakesy
Post by Oakesy » Wed Sep 21, 2016 7:11 am
I had my pads and Wear sensors replaced less than 1k ago after then doing around 40k. I was also getting random brake wear alarms. When the garage changed them they found corrosion on the connectors from the loom for the wear sensors, which is a common fault apparently.
As an independent specialist they carried out an 'Audi recommended repair' which is effectively a new plug with pins and spliced using solder sleeves. Not a problem since.
Daytona B7 RS4 Avant
SS+, MRC Stage 2, Valved Non-Res Miltek, Ceramics
Possibly up for sale soon
andyg72
Post by andyg72 » Thu Sep 22, 2016 7:54 pm
Yea that could well be what's happened I'll know more once I've taken them out and see the condition of them
Users browsing this forum: beckford21 and 230 guests
